Finally planning the farm shop
mossbackfarm
NW OR
Hi GJ!
Longtime lurker, and I’ve gotten tons of useful information over the last few months as my new shop has been brewing in my mind, so Thank you already!
Now, the timing is coming together, and I’m looking to pull the trigger in the next month, for fall construction. I’ve got some ideas and a vague plan, but I’d like to run them here, and see what people think.
The plan is to make a place that I can maintain and store equipment for the farm, out of the rain. Novel, after 10 years of living here, I’ve never had a space to do that, and my stuff shows the abuse. There’ll be an upstairs portion on the loft as well…I’m not sure what I’ll do with that, but an office for me, a music studio for my wife, or a living area are all potentials…I figure if I build it, they will come.
The plan is to have a local contractor put up the pole building, after me and a friend with a cat do the site prep. Then finishing out the inside will be me, as friends and beer and time and money allow.
Here’s a rough look at the building(24Wx36Lx14H). Not the best at sketchup, but it works if I put the time into it.
picture.php
picture.php
Here’s the current site. Pardon the mess…10 years of accumulation that I’d really started to get a handle on, but a bad woodshed roof is getting replaced, and all the loot in there got hauled out. Easier sorting!
picture.php
picture.php
I’d prefer the site to be more to the left and back, between the house and the big tree and well house, but not only is the septic tank there, but it turns out the folks who built the place put the septic tightline and well water/power feeds there, widely scattered. Grrr. I can put an unpermitted (up to) 10x20 building there, but not much else.
So, here’s my questions and thougths (of the moment!)
Size / use: What’s the gut feeling on this size? Depending on funds, I might have to pull the rightward overhang, making it 24x24. I figure I can add that / an additional enclosed area as I see what’s working over time. I know these things are never big enough, so if I plan for expansion, I hope I’ll be ok. One additional possible use is an attached greenhouse at one of the overhead doors for heating and gardening, but that’ll depend on getting a better-than-current water supply, but a rainwater tank is on the wish list.
Orientation: I think the building would look more “welcoming” from the road if the gable end was facing that way, but then I think the options for expansion might become more limited.
Also, our place looks pretty “junky” compared to some of the high end houses around us. This might make us more of an appealing target, and then welcoming doesn’t work! We don’t have much valuable portable stuff, but the yahoos don’t know that. Also, I’d be interested in a solar array someday, so the current orientation optimizes that.
Site prep: The site has a slight grade… 1-2% There’s a pile of fill behind it from when the house was built that I’m cleaning up. I’d prefer not to cut too deep by the big tree, but do you think that using the current fill (40’ x 20’ x ~2’, before the grass/etc is scraped off) will get me level? I can do the math, but sometimes these things throw in variables that simple math just doesn’t cover
Utilities: The well behind the big tree has a 60A service. I have a feeling that’s just not going to be enough, even for the more domestic uses. That leaves me with either running off the house, or getting a new (and paying forever for) electrical service. This pic shows the layout.
picture.php
Red is power, the bottom one is service from the power company, the paired with blue one is power for the well from the house. The paired blue is the house water supply, and the single blue is the septic tightline out to the drainfield. The pinkish colors are potential routes to run them. I need to keep at least 20’ from the tree, or alternatively I could run things down the inbound service line. But it seems that trenching that out would be a huge headache. A friend is plugging his airknife, but figured I’d get a sense for what people think here. Water would have to come from the well through an additional trench that could possibly meet up with the final electrical configuration.
I think that’s just about it…sorry for the wall of text, but I suspect folks here like to think about this stuff :eek:
Thanks,
Rich
mossbackfarm
NW OR
The 24' depth doesn't leave much room when working on a full size pick up, just so you know.
Aha...been a Tacoma driver for a decade, but I posted this for the insights I've missed. Thanks! Might work on stretching that some
larry_g
oregon
one thing I see is you have no headroom where the stairs hit the loft. Plan your stairs so they land near the peak of the roof so you have head room. My build below has a loft that you can glean for ideas.
lg
no neat sig line
RickP
Annapolis, MD
lg
no neat sig line
Maybe add a landing and turn your stairs 90 degrees before they reach the loft? That would give you headroom above and room for a closet below.
RickP
Annapolis, MD
I'm a fan of doing things in stages. That 60A service at the well sshould be enough to get you started for service to the garage, and you need to run a trench from the well anyway for the water. Later, you can add electrical service from the house, but you'll probably need an upgrade from the PoCo to do that anyway.
Posted from Garagejournal.com App for Android
John in OH
SE Ohio & Eastern Virginia
+1 I don't know what kind of farm equipment you have, but 24' depth sounds way to short. My F150 with extended cab is about 22' long. If you have a decent size tractor you won't be able to bring the tractor and implement into the shop if depth is only 24'. For a farm shop I wouldn't go anything less than 30' deep at a minimum.
Do you plan to keep a vehicle parked behind the left O/H door? Does the 36' dimension include the carport area? If your enclosed area is only 24' wide and you want to use the left side for parking, you're going to be way short on shop floor space for overhauling equipment. Suggest that your enclosed space be at least 36' wide.
What is the height & width of the right O/H door? Again, don't know what type of farm equipment you have,, but this door should not be less than 10' high and 10' wide ... 12' wide would be better .... and here I'm assuming you don't own a self-propelled combine with a 40' head!!
Don't skimp on the base dimensions. Most implements usually require a lot of space to horse them around for repair work and nothing is more frustrating than spending a pile of $$ on a new shop and then finding you can't work on your equipment because the floor space is too small.
Upper floor access - some jurisdictions do not allow access to an overhead garage "living space" (whatever that means) to be solely from the interior of the garage - too high a risk of garage fires and resultant trapping of people on second floor with not means to escape except via a flaming garage space! An exterior means of access is often required.
5lima30
Mountains of Western NC
I agree with the others I think you will need a deeper shop! I would also suggest having a bay that is drive-thru or at least an open covered area that is drive-thru. Some farm equipment is difficult to back in. Some sort of overhead hoist would also be good to have as well. Good luck!
mossbackfarm
NW OR
That does seem to be the consensus! The rightmost bay is planned for drive through options, but I might head back to the drawing board and make it wider. Tractor is a 53hp JD, and I don't do any combining, but a mower and a bale spear gets pretty long
Gah....that's a good detail. I popped the stairs in there kind of on a different configuration, but never moved them when I started settling into a design. And I really like your build!
Probably not permanently.
~10'w, 12' tall
And that's a really good point. Time to check with the permitting folks.
Thank you so much everyone....keep 'em coming!
EDITED because I missed one:
I like that thought...everything on the farm is "Do as much as you can handle/afford, until you bump into a constraint." Worked pretty well so far
John in OH
Years ago when I was planning to build my first new workshop, I was telling an elderly neighbor about my plans. He considered what I'd said, then offered the following advice, "Seriously figure out how much space you're going to need to do what you want to do. Then DOUBLE it. Then, MAYBE, it will be big enough!"
mossbackfarm
NW OR
Seriously...problem is, there isn't enough money in the world to build as much space as I think I need...and then double??? :)
Cougar
Wisconsin A little south of the Frozen Tundra
That's some good advice.
