ilya
This motor came with the drill press I purchased a few months ago and when I took it apart for cleaning and bearing replacement, I did not fully label the wires going from stator to the terminals. I could use some help in figuring out how to connect the stator windings. Below are some photos and additional information.
Thanks!
1. Stator. Wire labeled #4 connects to capacitor. Wire #2 I think connects to neutral (based on some forum posts of people having similar problem)
Table showing resistance measurements of stator wires
From the above it seems that Green + Red are the run winding and Yellow + #4 are the start winding. Does it make sense that cable #2 connects to neutral and that there's resistance between it and Green and Red wires?
Additional photos:
2. Name plate. Based on the instructions for reversing the motor, it looks like yellow leads from centrifugal switch and stator Yellow wire connect to different terminals and it doesn't matter which ones. If it runs in reverse, I can always switch them.
3. Toggle switch. 1 wire connects to hot, the other to thermal reset switch
4. Thermal reset switch. One wire connects to toggle switch.
5. Capacitor. One wire connects to wire #4 on stator, the other to centrifugal switch.
6. Centrifugal switch. One wire connects to capacitor, the other to one of the terminals. Which one?
7. Terminal plate.
8. Rotor
Thanks!
Code:
| | Green (G) | Red(R) | Yellow (Y) | #2 | #4 |
| Green (G) | XXXXXXXXX | 1.5 | | 0.6 | |
| Red (R) | 1.5 | XXXXXX | | 1.5 | |
| Yellow (Y) | | | XXXXXXXXXX | | 7.3 |
| #2 | 0.6 | 1.5 | | *** | |
| #4 | | 7.3 | | | *** |
Additional photos:
7. Terminal plate.
8. Rotor
