pattenp
Fix Tip: LiftMaster 3800 loose position sensor gear loosing travel limits
Just an FYI. I spent about half a day trying to figure out what the heck went wrong with my Liftmaster 3800 opener. When I tried to open my garage door it went up a couple of feet then stopped. I tried to close it and it shuttered going down and stopped a few inches off the floor. I went back and forth trying to get it to open and close with no success. So I thought I needed to reprogram the travel limits. I tried to reprogram the limits and the same thing; the door will only go up and down a foot or so. After a lot of trying different things and fiddling I opened up the opener. After observing how things operate inside I noticed that the gear that turns the position sensor was slipping on the shaft. I tightened the set screws on the gear and problem was solved. So if anyone has a problem where the opener is not opening and closing all the way, check to see if the position sensor gear is loose on the shaft. It was just dumb luck that I noticed the problem. I was about ready to buy a new logic board.
See Set screw marked by red.
View media item 54906
