Crimpers: Channellock 909 vs Klein 1005 vs Other?
Davefr
OR
I'm looking for set of dedicated crimpers. (not universal wire cutter/wire stripper/screw cutter combo tools).
Is there any significant difference between Channellock 909's and Klein 1005 for general purpose insulated and non insulated terminals ranging from 10 to 22 AWG?
Channellocks are cheaper. Is there any downside?
Is there another brand worth considering? (non ratcheting)
4x4gearhead
New Hampshire
Either one of those will do the job, its hard to tell the difference in quality between the two as they are pretty much the same tool.
jakemac
New England
+1 on Thomas & Betts !
I bought a pair of WT-111-M's in the late 80's and they're still going strong. Well worth the money.
Brownsfan
Cleveland Ohio
I have all 3. Why? I don't know. But I prefer the Klein. I will say the wire cutter on the channellock is better. The kleins crimp with the least amount of leverage which is important when doing a lot of crimps per day
box
Toms River NJ
ask 3 different people get 3 different answers...I have done a ton of crimps back in the day and the Channel Lock were hands down my go to tool, better then T&B, Klein and the Snap on version
I think the Channel lock are a little wider in the crimp area and have a more solid feel...
This is however, just my opinion, all will do the job just fine
ATC
VA
****....I just ordered the 909's
The kind I currently have, are the ones that crimp behind the joint...back inside the handle area. I've always hated that style...
D
Davefr
OR
Thanks. I just picked up the Kleins at HD.
The Channellocks and T&B weren't stocked at B&M.
jeffmoss26
Cleveland, Ohio
I like the 'non-insulated' crimp part of the Kleins the best. I use that for insulated terminals as well. One of the old time sound guys I worked with taught me that trick.
Brownsfan
Cleveland Ohio
I do the exact same thing. That's why I actually prefered the 1006. But I lost them and could never find them again locally. So I just used the 1005 and got used to them and the rest is history.
D
Davefr
OR
OK guys. I made some test crimps using ordinary hardware store blue insulated terminals and my Klein 1005 with 16 AWG wire. Here's a test crimp using the "INS" die:
I really like the quality of the crimp. Wire strands are evenly distributed and the crimp runs almost the entire length of the tube. (I sliced off the blue plastic insulator to have a peak inside)
Now here's a crimp using the same type of terminal/wire using the "NON" die. Notice a smaller portion of the tube length is crimped and the wire strands are not evenly distributed (bunched up in one side). In fact some of the strands aren't even in the crimp!!
At least for these terminals, it seems like the "INS" die produces a superior crimp.
jmm
NC
Anybody try the newer Snap-On design? The little ones? How do they compare to regular sized crimpers. I've never tried T+B or Klein's, but I like my Channellocks just fine.
jakemac
New England
Part of the problem with the second test is that you indented the terminal on the side with the seam, the indent should be on the solid side opposite from the seam on the terminal. That lets the tool cradle the seam so it is less likely to separate. It should give a more even crimp.
D
Davefr
OR
OK, here's a crimp using NON with the tab hitting the side opposite the seam. It's better but still doesn't crimp the entire length of the barrel.
I think I'll stick with INS.
kenfain
just west of Walton
I needed a dedicated crimping tool also. Happened to be in hf. when I spotted a pair for five bucks. Have to admit, I wasn't expecting much. First time I used em, I was impressed. They are heavy enough, and they fit my hand comfortable. Easy to crank down on. Made a good.solid crimp. Now I'm not saying they're better than those others, but five bucks, it's worth a look.
jmm
NC
The regular crimpers or the ratcheting pair? The ratcheting pair were on sale a few months ago at my local HF. The regular pliers I would probably try but, without hearing some glowing review, the ratcheting pair is something I'd steer well clear of.
LXCam
I have a few sets of both Klein's and T&B. I honestly have no opinion on which Is better.
But this I do agree with.
And Dave, it apears that terminal was too large for that conductor. What size were you using?.
mickeyone
northern NJ
I have kleins,ideal,and Thomas and Betts The T and B are the best 111m model. I have an older one as well with no cutter,that ones better in tight places.The old vaco 1900 also has reputation in theatre/film industry. Its an individual preference.
D
Davefr
OR
I was using 16 AWG wire in a Blue terminal. Blue is for 14-16 AWG. I could have also used Red which is for 16-22 AWG.
Is it better to go big or small??
LXCam
Agreed on the sizing. But the greater the space taken up by the conductor the better fitment qualities imo. And please excuse me, seeing pictures on my phone doesn't always work out so well. It was difficult for me to make the judgement call on the sizing.
jakemac
New England
It's not supposed to. By leaving un-crimped ends, it is less likely that the wire will pull out over time. If you crimp the whole terminal socket, you also flatten the end of the wire, making it more likely that the crimp will fail under stress.
D
Davefr
OR
Thanks, I'm learning a lot about crimping. Which of the previous crimp images is the best?
metaldad
nw indiana
Agreed
die is the same depth, whether ins. or non. on my various crimpers, i never use the ins. die. i always use the non, with ins. stacons.
yellow with 12, blue with 14, red with 16
and, I have all 3 crimpers mentioned.
jakemac
New England
The last crimp looked good. But the indent should be more centered to the socket, and the wire could have more of a twist before crimping to keep the end from flattening. But then, when doing a lot of crimps on the job, most will look like that (many of mine have). It's fine.
Crimping and Cramping go together.
-- If my posts sounded snarky when read, I apologize. That isn't my intention. Print is a ***** to keep a light conversation going. :dunno: --
dleonard1122
New Jersey
... And I thought crimping was one of those "you really cant mess up" things. Learned alot from these two pages already. I definitely want to get a dedicated crimper now.
+1. I feel like I have to put so much force into a crimp because I'm not getting nearly the amount of leverage I probably would if the crimping "part" was at the end of the plier.
Not much to add as far as experience, but I'll prolly just get whichever tool between Channellock or Klein that I see first locally and is a decent price.:beer:
Chuck122
Québec, Canada
They are great. Although I do not own any of the pliers above, I can say that the crimps look real good and solid. They are small but the fact that the crimping dies are really close to the pivot point actually give leverage that would not be expected from such small pliers. The cutters and strippers are nice too. I also find that the gripping end at the very end of the jaw usefull allaround . I am glad I bought them
plinker
Northern Wi
I've got the Klien 1005's and just bought the 909's, I havent really used the 909's much yet to have an opinion, but I really like the Klien's. I mostly use insulated terminals at work and use that crimp location on the pliers.
At home, I use/prefer the non insulated terminals with shrink tube.
For the yellow 10-12 terminals, I like the Tool-aid ratcheting crimper, it makes sure you get enough crimp applied. The other jaws for open barrel and non-ins. terminals are nice to have as well.
I do not care for the Snap-on PWCS7CF crimper. I dont think it's enough for the yellow terminals for one and, I've seen too many people not crimp terminals properly with one (Not the fault of the tool itself).
monster1
The dies are backward and upside down on the ratcheting crimpers I saw in hf. Poor copy of a good design imo.
ATC
VA
I spent all of 34 seconds searching, and found the 909's for $13.65 at www.tooldiscounter.com With shipping, it cost me $23. That's on the low end for what I see other Channellock pliers going for in stores and online....so I bit
cyato
Orange County, CA
For blue and red connectors, I like my old Blue Point crimper which is a rebadged Ideal 30-429 that CWP1616L posted and very similar to the Channellock 909s. I always felt that a wider crimp was better, but crushing the **** out of a connector is not good either. I have several pairs of the Snap On PWCSS7CFs and although they are handy, it takes a decent amount of pressure to make a proper crimp. If I was making a couple crimps, they would be fine, otherwise I would opt for the Blue Points.
For the larger yellow connectors, I use my Blue Point 29CFs which are rebranded Ideal 30-425s. They are beefy and make a very proper crimp on 12 to 8 gauge connectors. For 4 gauge and larger, I have a modified HF hydraulic crimper that works great.
