While I was at Lowes today I noticed that they had a Kobalt 80 gallon Model #137603 compressor marked down from $699 to $384. I would generally use it for misc items, but I would like to be able to sandblast rims without any problems. Does anyone have any experience with this model?
Here are the quoted specs:
Great for heavy-duty use - integrated control panel adds convenience
16.1 SCFM @ 40 PSI
14.0 SCFM @ 90 PSI
155 maximum PSI
4.5 HP (stated as "running" HP)
Vertical stationary tank
Hi-Flo, cast-iron, single-stage oil-lubricated pump
Heavy-duty induction motor
Amps: 18.6 - 17.5
Power Supply: Electric
Volts: 208-230
Start/Stop Control: Yes
Tank Capacity: 80 gallons
Lubrication: Oil
16.1 SCFM @ 40 PSI
14.0 SCFM @ 90 PSI
155 maximum PSI
Amps: 18.6 - 17.5
Volts: 208-230
Lubrication: Oil
