Anyone here have a tire and balancer at home?
WhyMe
One of the much wanted things I would like to have is a tire machine and balancer. I know they are expensive, but i would try to offset it by doing peoples tires.
So anyone have a set at home?? was it worth the cost and do you use it often?
IndyGarage
Indy
Yes, for a couple years now.
I first bought just the balancer for $300 . It's an old Snap On manual spin computer balancer. With it I can get my tires better than I ever got from someone else.
Then I found a fairly basic Atlas changer used for $500. Add about $300 for supplies and tools - Wheel weights, valve stems; tire mounting goo; wheel weight pliers, etc.
So I have about $1100-1200 in the setup. I figure I save about $300 per set of tires that I mount and balance myself. That's about evenly divided between purchase cost, mount and balance cost and keeping them longer because I keep them balanced correctly. I think I probably spend some of that on better tires than I would have bought locally.
Time savings is a wash, because it takes me about the same time to do it myself as it would to drive to a store and wait for someone else to do it. I can't do it as fast as the pros do. Certainly it's hard physical labor, and changing tires can be a real dirty job.
So far I've done about six full sets of tires and multiple rebalances and repairs, so if my math is correct, then I'm in the black on the equipment - everything from here forward is free.
The only downside I can think of is that the equipment takes up some room in my garage - maybe an 8 foot by 4 foot area for both pieces - plus probably double that for working room when I'm using them.
I haven't had any trouble at all with the balancer - but the electronics seem a little mysterious. I suspect if it breaks I'll just throw it away and buy another used one, because fixing it will cost more than it's worth. I was originally disappointed I couldn't find a motorized balancer because I thought they were better, however I'm very happy with the manual spin. It balances just the same, but has fewer moving parts to break - plus it is so lightweight I can move it around where I want it.
The changer had a small problem with the bead breaker early on, because the previous owner didn't have dry enough air and moisture got into the cylinder. It was a pretty easy fix, but did take a couple hours. Since then it's been fine. It's not a real complex machine.
I'd thought about it for a long time before I bought them, and that was a mistake.
bannerd
Upstate NY
I dropped $1800 on my tire machine and tire balancer. Bought both of mine from ASEdeals.com Rangers).
Is it worth it? The first time I took my tires to a shop I was told that two of my tires were shredded. I went back to the shop and noticed that my tires were shredded. These were $150 per tire that I just bought for winter. I ended up losing that battle in court because it was to small of a claim. I took my tires to a word of mouth shop that had five stars. When I got my car back the tires were on but my wheels were scratch. I have a very soft Alcoa wheel (aluminum) and very expensive. They did buy me three new ones which I was happy about. Now I don't worry about it, I take my time and do my own. Actually I've gained a few customers. Some of these guys wait a few days but don't mind that I work slow and do the job right. Quick way to make a $100
RCStocker
Indiana, California, Australia
I have an old Snappie bubble balancer I paid $40 for 30 years ago. I have an old tire machine I bought at the same time for $40. I change the trailer and boat tires all the time with them. I do small tractor tires and cart tires.
My Lincoln rims are Mag's and I can't do them. They get mounted free and I really never need to do truck or car tires.
They are in my tractor barn shop on the farm.
I just take the trailer and boat tires to the local shop to get repaired or replaced. I don't have a need for them out here in California.
They have saved me a lot of time and money through the years. Well worth owning if you don't need to change expensive tires.
The last sop I bought out and auctioned off hand a nice balancer and tire changer. I sold it at auction.
Chuck122
Québec, Canada
If you have nice (large, low profile, expensive) tire/wheel setups, and do very few tire changes a year ( ie you are not experienced), you will need a more expensive machine to do a good job. Plus, if the rims are scratched, you cant get the tire shop to replace them.
I would advise against buying a tire machine as it takes up a lot of room, it is expensive ( to get a proper machine) and is seldom used.
firebox40dash5
$300 savings mounting and balancing a set of tires? You ever wanna sell your mount & balance setup, let me know, I'll even do your tires in the future for the low price of $200 a set! :D The shop I work at is generally on the lower end for tire prices (mounted & balanced) but by no means the absolute cheapest, and we usually come out about even with someone buying from Tire Rack and paying shipping on tire price alone, and charge about average for the labor... so I'm not seeing where cost savings aside from maybe $20/tire in labor (minus your own weights) would come from?
We have an old(ish) set of Accu-Turn stuff at the shop... I have neither the money, space or inclination to have them at home, though if I had the money and space and didn't work at a shop, I might gain the inclination. Paid $1k for the set ready to work, IMO within the range of the shadetree who wants his own machines. They're a little on the old and clunky side (the tire machine is a 2-pedal all-air, and the table spin is slow) for shop use but we don't do a whole lot of tires and the price was right... so for saving money at home rather than making it at work I couldn't complain.
As for doing other peoples' tires, I dunno how much you would REALLY make. We've got 4 kinds of weights (MC, AL, TC, FN) from 0.25-2.0oz./5-50g, plus stick-ons, and none of them are particularly cheap. At least if you're just doing your own you only need what your vehicles use, not stocking a bunch of stuff for the chance you'll need it for someone else, or running to the store when you do need it.
lessersivad
Morenci, MI
I bought an old Coats 40/40A a few years back when the shop I usually went to was talking about closing down. (They also had a Coats 40/40 but didn't want to sell it at the time.)
I also bought a bubble balancer about the same time.
Both have more than paid for themselves many times over.
I've found that my only limitation is I can't mount/dismount anything over 17" diameter tires.
Delray
Upper Peninsula of Michigan
I have a used Coates changer and a bubble balancer. I have trailers, trucks, tractors, old cars, rubber tired dray etc. so it's used pretty often. Yes it was worth the investment.
rlitman
Long Island
$300 savings mounting and balancing a set of tires? ... so I'm not seeing where cost savings aside from maybe $20/tire in labor (minus your own weights) would come from...
Well, I have winter tires. I switch from summer back to winter and back each year. Each time I switch, I rebalance my tires (and rotate).
For one vehicle, at $20 per tire for a re-balance (going rate here), that's $160 per year in balancing (I have three vehicles, only put winter tires on one, but rotate and balance the other two annually). My Snap On balancer ran me $400.
It has already easily paid for itself. I don't have the room for a tire changer.
CWP1616L
USA
What happened? I remember when the cost to mount and balance tires was $12 for the whole set. :confused:
Nanashi
Where I work mounting and balancing cost $15 a tire. That includes new valve stems and disposal of the old tire.
Balancing a tire is very easy but over the life of a tire it can move on the rim and or wheel weights can fall off causing the wheels to become un balanced. Mounting and removing tires takes some practice but is easy after a few are done. The harder ones are the low pro and the big floppy truck tires that need a big shot of air.
sberry
Brethren, Michigan
I got a snappy balancer but it doesn't seem to work right, I don't know what I am doing in the first place and it doesn't have adapter for 16 inch truck wheels. I have a coates 40A and wouldn't mind trading up, I should shop hard for different machine but this does 95%. I never wanted a machine, too many used tires around ha but it has been great.
I was hoping to use the little balancer and had it at the hoist for tire rotation.
IndyGarage
Indy
Bubble balancers are not good enough to get a decent balance on your tires. They will only do a static balance, not dynamic. With my balancer I can get my tires within .1 ounce dynamic - which makes a tire which you cannot feel at 80mph. It takes me about 15 minutes a tire to get them that good. Most tire shops spent about 2 minutes per tire and don't get them as close as I can.
I disagree.
I bought some pretty expensive 18 inch by 9.5 inch rims for my Miata and mounted 40 series Direzza Star Specs (very stiff sidewall) on them with my cheapo Atlas tire changer. You do not need all the fancy helper arms. I have a plastic bead clamp and a few cubes of 2x2 wood. I took my time and used plenty of tire lube and they popped right on. I ended up buying a Cheetah bead blaster because I had one set of tires that was pretty tough to get the bead seated, but that had nothing to do with mounting them.
Anybody who scratches a rim on a modern rim clamp tire changer is being careless. If you have the plastic clamp covers, you will be fine.
I would not recommend the old "coates" style center clamp machines - those things are junk as far as I'm concerned.
I've been questioned on that math here before. Here's how it breaks down: 1. $100 savings on the cost of the 4 tires - I can order from Tirerack or discount tire online and have the tires the next day almost always for less than I can get them locally. Of course you can get that savings if you buy online and take them somewhere for mounting as well - but I never did that. My wife also doesn't get baited and switched to another brand of tires when she buys them - which happened more than once.
2. $80 to $100 on the cost of mounting and balancing. Almost everyone here charges $20 per tire to mount and balance. Then they try to get an extra $6-10 for road hazard warranty. Then they charge $2.50 a tire for disposal. And last time I got $5 for "shop supplies" - I suppose that's hand soap or something. Anyway, I still have to dispose of my own tires, and if I want it Tirerack will sell me road hazard, so take them out. With tax it ends up about $100 to mount and balance a set of tires. And I have never had a set balanced as well as I can get them at home, no matter what the price.
3. When tires get old and they start losing their balance and making noise, I almost always got rid of them before the tread was worn out. Whenever I took my tires in for "free rebalancing" or even paid rebalancing, I would get the worst quickie job they could do. First because they weren't making money on it, and second, I suspect they really don't care if they do a good job in hopes you will come back in and buy new tires. Anyway, that's what I and especially my wife would end up doing. "These tires don't seem to be any good anymore, it's time to get new ones".
I figure I was throwing tires away 20% sooner because they weren't balanced right. At $500 per set (yeah that's the full retail, because that's what I'm comparing to) that's $100 in savings if I can balance them right and drive them another 8,000-10,000 miles - which I can.
But you cannot balance them right with a bubble balancer and you have to know how to work the balancer properly.
Add it up you get near $300 per set of tires.
I find it's a little more on expensive tires and a little less on cheaper tires. And I find that I eat some of the savings up by buying a higher quality tire than I would have in the tire store.
So what's not to like - better tires on my car, money in my pocket and they are better balanced than I could get at the store. As I said earlier it's a dirty and physically demanding job to change tires, but it doesn't take me more time. The only other downside is getting rid of used tires.
IndyGarage
Indy
I think I remember you got the same balancer I have.
It'll work good if you have the right adapter. You could probably turn one on a lathe if you don't have the right one.
I did a set of 16 inch truck tires on mine the last week. It balanced them fine, but they are heavy to put up on the spindle, and pretty hard to manually spin.
I found there are a few tricks to the balancer - first you have to make sure the wheel is mounted on the spindle correctly - the cone and spring are supposed to center it, but heavy wheels (like truck wheels) can overpower the spring, so you have to hold up on them with one hand while you tighten the nut with the other. Also make sure the wheel is facing up to the flat on the balancer correctly - sometimes there is rust on the wheel bolt face and you have to wire brush it so it sits flat.
Second, the way the balancer works is that it tells you where to place the weights in space to theoretically balance whatever is on the spindle. In other words, it has no idea what the size and shape of the thing you are balancing and doesn't care. The numbers you put in for the inputs determine where it calculates the weights should go. If you don't measure correctly then the weights aren't where it thinks they should be and you don't get a good balance. There are always three inputs: wheel diameter, distance to the near side of the rim, and distance between sides of the rim (rim width). I normally use stick on weights (because I don't want to stock 10 different weight styles) and they don't stick on to the outside of the rim, so you have to adjust your distances slightly for where the weights are actually going to be applied.
Third - make sure the settings are correct - there are four balance mode settings. I usually do mine on the "fine" setting and balance down to where the weight required is 1/10 ounce, then loosen the wheel slightly, turn it 90 degrees, tighten it back up and make sure it still is showing the same balance. If it doesn't, that means I didn't get the wheel mounted on the balancer correctly. I'll sometimes check the static balance, but if you balance on fine, it balances both dynamically and statically.
Your tire changer is the old style - I wrangled tires with one of them in high school and that was a long time ago, but it sure seems like the rim clamp style is much easier to use. I'd get rid of that thing and buy a newer style one.
fatfillup
Finksburg, Md
Indygarage, I was wondering about your math also, but it does make sense. Thanks for the detailed explanation.
In the mid to late 70's, I worked in a gas station and mounted a boat load of tires on an old Coats 10-10 tire machine. Couldn't touch an aluminum wheel but that wasn't an issue back then for the work we did.
As far as the manual spin Snap on balancer, I have used them and like them.
Would I have a tire machine and balancer in my personal shop,,,,,,,,,,,yes if I had enough room and had enough vehicles with steel wheels and could get the machines cheap enough. I have bad experiences with tire shops. Its always the low man on the totem pole who does tire the tire work and often they either don't know or don't care. Oh, that may not be true on the expensive wheels, I haven't been in the industry for decades
IndyGarage
Indy
Late 70's is when I did it too. I only worked there a few weekends to help out a buddy of mine - his dad owned the station.
And yes, we weren't allowed to touch an aluminum wheel. Now that's mostly all I do.
signcrafter
Think about it, 12 bucks is almost minimum wage for an employee. You can figure about an hour to demount, clean the rim, install new valve stem, mount, and balance the tire. Maybe longer if you have to take the tires off and put back on the vehicle. So 12 dollars pays for an hour of labor, not the shop overhead, insurances, taxes, shop supplies, electricity, new valve stem, air to fill, wheel weights, etc. It averages 20-25 bucks a tire for a mount/balance around here.
Filson
NE WA
Walmart - Lifetime Balance & Rotation for $8.00 a tire, or $32 for the set. Double that for your winter tire set, your in $64 bucks and can swap your tires, rotate and rebalance as often as you want after that for no additional costs. If you average, say 5 years for your tire sets - that's an average of $12.80 a year to let someone else do all the dirty work. :thumbup:
signcrafter
Sorry to me even if they did it for free that's not worth it. Way to many horror stories of walmart tire clowns. Some things are better left to doing yourself or going to a quality shop in my opinion.
IndyGarage
Indy
Last set of tires I bought in a store was at Walmart. We were driving through Mississippi in 100 degree weather and had a blowout on the interstate. It looked like two of the other tires were about to go, so we stopped in the next town and Walmart was the only place that sold tires still open.
I told the guy doing the tires I'd give him a $20 tip if he'd take the time to get them balanced good. He did, and I did. That's the best store balance I ever got.
Filson
NE WA
Can't argue that too much, I've heard some horror stories too, but I've heard them about a number of shops, so hey. A buddy of mine works in the local shop and I trust his work, and only get any service done when he's working. But at the same time - balancing a tire and stuff isn't exactly rocket science, most of the "clowns" should be able to do it without issue. I personally, haven't had an problem yet. *knock on wood*
Nanashi
Dude come on. **** Walmart and their anti America agenda. Plus they pay their mechanic's minimum wage I'm sure. I don't know that but I wouldn't question if it where true. Regardless Walmart is the damn devil
firebox40dash5
I won't let them touch my lugs, I bring them wheels and tires. Never had a problem with their mount and balance. But the one time I let them touch my car, I got horribly warped rotors a few hundred miles later. Checked the lug nuts, and I had to stand on a breaker bar to loosen them... on a Civic. :wtf:
Admittedly, hauling them a set of tires and wheels is a hassle, though.
Steevo
43.49600, -112.04300
My last tire mounting machine was one of these:
And I had one of these balancers:
images
Nowadays, I go to the tire store.
PowerDubs
I bought a Corghi tire changer and a Coats balancer for my garage at home.
I've used the changer numerous times, enough that it has paid for itself. I tried the balancer, but couldn't figure out how to use it I guess.
I'd let it spin up, do it's thing..then put the weight where it showed me. I'd then spin it again to check, and it would tell me to put another weight in another spot.. so I did. Spin a 3rd time to check and the cycle continues. I just said screw it and never used it again. I've just been leaving the weights on the wheels and they ride fine. My guess is the weights are more for balancing the wheel itself moreso than the tire. They seem to ride the same on the old tires VS new if the weights are left on.
Thoughts?
IndyGarage
Indy
Thoughts?
Read my reply earlier about running a balancer.
Having balanced several hundred wheels, I'd say the tire is more often the culprit on aluminum wheels and the wheel moreso on steel wheels. Steel wheels are heavier and seem to bend more.
You either didn't get the wheel mounted on the spindle correctly (likely) or you didn't get the inputs for your wheel correct (possible if you don't know how to do it) or you didn't have the machine calibrated (less likely).
jdjm
I have a coats rim clamp and a hoffman tire balancer. Reason I bought it is with 6 cars at home when they run over a nail I take them apart and patch from the inside. It's also great because I can change quad tires and it definetly paid for itself many times over
IndyGarage
Indy
My thoughts in bold. I'm not knocking your decision to buy a machine, but the numbers don't add up to me.
It's obvious you're happy with your decision to purchase a tire machine and balancer, and that's what matters. :beer:
But the $300 per set doesn't work out for me. The most I could save is $80 per set of tires + tax, so buying them isn't financially smart in my case. I'd like a tire machine and balancer, since I already know how to use them, but I can't justify dropping a significant chunk of change on them for kicks.
That's fine, however all of them are real for me - plus I run tires that are much better balanced and quieter than they would be even if I got "lifetime balance". I know for a fact that they don't take the time to balance them really well in a tire store and that's why they won't last as long.
joe_padavano
Northern VA
I bought a used rim-clamp mounting machine and Hunter 700 balancer for about $350 each. The local gas station charges $15 a tire to mount and balance, so economics are not why I did it. Convenience is why. I have limited time to work on my cars and that time is usually when the gas station is closed. Couple that with having to leave for work before they open in the morning and getting home after they close and there's just no way to easily get tires mounted and balanced by someone else.
Of course, there's the added advantage that any scrapes to the wheels are my fault, so I take extra care.
The other reason is to avoid the idiot "your truck is four wheel drive so we have to sell you four tires" mentality. Apparently tire shops can't differentiate between part time and full time four wheel drive. I just buy tires from Tire Rack, they show up on my door step two days later, and I can mount and balance at my convenience. With all the vehicles I own, I average about 8 tires a year, so the $120/year savings takes a while to pay off the machines.
Frosthy
FL
If you can find lead wheel weights, get them. I find them much, much easier to use/hammer on.
For aluminum/pretty wheels, just order some sticky weights and clean the rims really good.
mikegt4
sw ohio
Anyone here have a tire changer and balancer at home?
Actually he moved out several years ago. He works at a dealership now so I get mounting, balancing and puncture repair for free. Of course if I added up the cost to raise him I am not getting my money's worth.
srmofo
SW ohio
s
It still doesnt make a bit of sense to me.
1st - you can get the discounted price from tirerack regardless if you have the equipment, so subtract that.
2nd - balancing doesnt cause a noise, it may cause a symptom that leads to a noise, but that symptom isnt going to disappear magically over night with a new balance job. So subtract that $100 also.
3rd - you have to buy the supplies for that mounter/balancer. Wheel weights and valve stems are not free.
What are left with, the $100 or so it costs to mount and balance a set of tires, plus what ever you save from doing your own repairs at $30 each. Theres also some value to doing the job the way you want when you want it. Personally though, you can tell yourself whatever you want. You dont need to justify your purchases to me or anyone else for that matter.
I wouldnt buy the machines for 2 reasons.
1 - I dont want to sacrifice the massive amount of floor space they both require
2 - I have access to mounter/balancer anytime I want.
Greatbear
Columbia/Fulton, MD
I have a Ranger rim clamp changer and Ranger DST1000 balancer in my little home garage. I like being able to do my own mounting and balancing, I can fuss a bit over positions of weights and such and end up with a minimum of properly positioned weights over having the typical shop sprinkle them all over the rim diameter. Sure, it takes time, but the job quality is far better and seems to stay more in balance over time. I also don't have to worry about having expensive aluminum rims damaged, TPMS sensors broken, etc.
It's not a problem, really, but friends do know I have the stuff, and I help them out too. I've corrected shimmies and wobbles that tire shops couldn't iron out. One wheel had almost seven ounces of weights all over the inner and outer diameters, it took me less than two ounces after remounting the tire to make it right.
