7th Kahuna
This past weekend, one of my neighbors was having a garage sale. I walked over to take a peak and in one of the boxes I found a Craftsman 1/2 hp Reversing Variable Speed Motor (model 266.23450). If it hadn't said Craftsman on it, I would never have guessed. I asked the guy if he knew what it was for and he said he thought it was a garbage disposal, adding that he wasn't really sure and that I could have it for $5 if I were interested. For $5, I figured I couldn't go wrong. When I got it home I looked up the model number but to no real avail. There are only two mentions of it that I could find. One suggested that it might have come from an Atlas lathe. I checked the Craftsman OEM list on the OWWM site but '266' is 'unknown'.
I am particularly curious about the accessory port which appears to have also offered some sort of remote control option.
So does anyone here know anything about my $5 Variable Speed Reversing Garbage Disposal?
I plugged it in and it works. You may note in the second picture that one of the mounts is cracked. The arbor has been adapted to threads (Craftsman adapter) though the actual arbor is smooth and keyed. The only clue to it's use, is a note that it is suitable for intermittent slow speed use and continuous high speed use. I would think that precludes it's use with a lathe.
I also found a 10 amp old school battery charger. Just what the doctor ordered for the electrolysis tank . . .
Needless to say I had to pass.
Brain fart I suppose. I hadn't downloaded any of the late 60's catalogs; grabbed the 1969 catalog while you were adding the image. There it was, both in the motor section as well as being featured with the drill presses.
