signcrafter
- Joined
- May 9, 2012
- Messages
- 12,414
I bought a wheelbarrow from home depot about 6-7 years ago. It was one of the nicer ones they sold at the time, think it was around 75 bucks or so. It's a plastic tub, think 6 cu ft and I've worked it pretty hard. I bought it originally when I had to dig up the yard to fix a basement leak. It sits leaned up against the garage most of the time but when I have yard work to do it gets used for moving dirt, stones, sticks, or whatever I can throw in it and for mixing cement. The legs had gotten a slit bend in one of them a couple years back, more of a twist or something but nothing that affected using it. Today I was using it to mix some cement for some fence posts and after the first batch I noticed the plastic tub had developed a crack in it. Not exactly sure what caused it. The only thing I can think of is I was hauling about 6 bags of 60 pound concrete mix in it and going over some rough terrain. Wouldn't think that would have cracked the plastic tub but who knows.
Anyway, I am now in need of a new wheelbarrow. I'll keep this one and retire it as the back up. So looking for a wheelbarrow that will stand up to some rough duty. I didn't think I pushed my last one to bad, like I said it only gets used a few times a year but when I use it I load it up with a few hundred pounds and run it across bumpy terrain. I will use it for moving dirt, rocks and mixing cement unless I can convince the powers that be that we need a cement mixer since after mixing 15 bags today I don't ever want to mix another bag! But don't think that's going to happen. So what are the pros/cons of steel or plastic tubs? Obviously plastic won't rust but as I found out today it does crack. So I'm leaning towards a steel tub but not sure since I would think gravel or mixing concrete would scratch it pretty good and leave it able to rust away. Also one or two tires? Anything else I should consider? Just want something that will last a longtime.
