Vw/ Audi rear caliper rewind adapter?
turdferguson13
You don't need an adapter. You need a VW scan tool to retract the electronic parking brake.
Veto
Denmark
Hmm... Didn't know you could rewind it with an adapter. I usually use VCDS for EPB's on VAG cars. Don't those universal brake rewinding sets have one that fits?
davesnothere
phoenix, az
I've heard the newer ones need to be done with a scan tool, or you'll be buying calipers. Haven't seen one in realtime yet though.
Subyroo651
Northern IL.
It says right in the product description
"To be used in conjunction with electronic park brake tools but not instead of them"
You need a VAGcom or similar tool.
T
tjmonsen5
Crystal Lake IL
I have a solus ultra which can do it. It makes it quite easy actually, just hook up a battery charger to the car, leave key in position 2 and leave scanner connected while doing the repair.... I just need the twist in adapter now. I have the Lisle 25000 turn in tool, which comes with about 5 adapters but not a 3 prong.
The computer may pull the ebrake in and release tension on the caliper, but you still need to push it in deep to make room for fresh pads.
G_P
Central CT
Damn... Cars are getting ridiculous. Cant even do brakes without a computer. That is amazing.
German engineering! I worked on some 80's VW's and hated it. I can only assume the newer ones have gotten even more oddball and complicated.
Sent via carrier pigeon.
T
tjmonsen5
Crystal Lake IL
Has anyone done brakes on any VW with the electronic e-brake? I have read a few posts on forums about people working on Passats, and those guys used just a C clamp to push the piston back in after using software to retract the electric motor...
I have the piston pusher tools and the twist tool... maybe you dont need to twist the rear caliper in? But then why does that company that I linked to in my original post offer one?
T
tjmonsen5
Crystal Lake IL
Found another post, appears that cars with Electronic Parking Brake do not need to be twisted in, just pushed in like a front caliper (after the scanner retracts them) Only older Audis with a mechanical cable operated parking brake must be turned in.
No wonder I couldnt find any information about this 3 prong adapter, it doesnt exist! But for some reason it does in europe... who knows. Why would the piston have 3 slots in it? I guess it will remain a mystery.
PowerDubs
Just a bit. (and this isn't even a 'new' one..since the Phaeton came out a decade ago.)
Dave455
Sussex, England
This is typical with many German cars!
Folks buy them because they are generally well made, but they are also getting more complex! The Germans seem to misunderstand and think that people actually want to buy a car that needs 15 computers. Big mistake, and you only have to look at the resale value of these big complex cars to realise that!
Just make a well built car with reasonable performance and keep the electronics to one easily replaceable engine management system and we'll all be happy!
firebox40dash5
Yup, push it straight in. Piece of advice, pull both calipers and put a screw-type retractor on one, do the other side completely, then go back and do the first side.
About a week after the first one I did, the 80ish year old owner of the shop next door comes in asking "Do you have some funky 3 prong caliper adapter? I tried using a bunch of different ones, but they wouldn't do it, even with the impact gun!" I about **** myself laughing as I explained that one, and offered to loan him our Launch. "Naw **** that, I'll just put it back together and send them to the dealer." :lol:
murphaayyy
Towson, MD
just saying i would not consider the phaeton to have average electronics, it isnt just some dressed up passat. it has a dehumidifier for christ sake lol. but i do agree its a bit much......
Veto
Denmark
Uhm... I'm pretty sure that aircondition dehumidifies as well :D
T
tjmonsen5
Crystal Lake IL
Just wanted to update this thread for information purposes. I should have just used my regular pad compressor the first time instead of assuming they needed to be spun in because of the notches on the caliper. The calipers pushed in extremely easily, probably the easiest of any car I have worked on. Working on that Audi was a dream, everything aluminum, no rust. Nice and clean.
