Parker vise no. 172 restoration year 1867
Swan
Winona, MN
I picked up a Parker machinist’s vise no. 172 yesterday at a farm auction for $35 and spent a few hours breaking it down, degreasing, blasting, priming and painting it. This is a beautiful old vise and works very well. The only flaw is it is missing the collar or garter on the front spindle so I will have to fabricate one to hold the dynamic jaw to the spindle. My Wilton C1 1845 vise is working beautifully but I wanted a second vise to put on a new workbench in the basement of my motorcycle shop, this was perfect for my needs and a steal.
It weighs just over 50 pounds and has 4” jaws. Cast into the body are the following letters:
right side “C. Parker
Meriden Ct."
left side “Pat May 23
Nov 26
Dec 10 & 17 1867
No. 172”
Before:
After
I broke it down, cleaned it and ran it through my parts washer.
Next, I went down the street to my buddy Skip’s machine shop and used his beautiful blasting cabinet with a very fine grit blasting media to clean off all the rust.
There were the usual scars from normal use, (saw marks, drill bit slips etc) no flaws, repairs, crude welds and for once, no hammer marks on the top of the slide where the dumb pervious owner used it as an anvil. The jaws are in very good shape too.
The static jaw has a removable pin with a chain allow it to swivel for unusually shaped objects (?) This is strange design I have never seen before.
I wiped the blasted parts with lacquer thinner, primed with Rustoelum clean metal primer and then painted several coats of low-gloss black Duplicolor high temp engine enamel. I did not find any information on this no.172 and assumed it was originally black. The low gloss looks right and reminds me of the black japanning found on Stanley planes. The cast letters were painted white and it looks much better than it did in the morning when I bought it. I lubed the main screw with anti-seize lubricant, the slide and handle with a light coat of lithium grease, and split a 5/8” ID inner diameter rubber grommet and slipped the halves the over the ends of the handle to serve as cushioning.
note missing collar
Once I fabricate a new collar this vice will be ready for another 150 years of service.
I am however having a difficult time finding any information on this specific model no. 172 vise and would really appreciate any links to its history, images, patent drawings, advertisements etc. Was this made in 1867? I believe there may be a Parker tool book too? Also, this is a long shot, but if anyone has a Parker vise collar I would like to buy it. Thanks!
CNGsaves
KS and OK
Wow, great vise . . . . excellent restoration !! :thumbup:
Can you post up some pics that illustrate it's movable rear jaw??
Also, be sure to post up some pics in the Vises of GJ thread.
bluebolt
Benton LA
Swan:
You gert a "YOU ****" for buying that vise for $35!
Your restoration gets an "A" from me!
That is an unuusual and very cool vice. I bought a 1930 patent date Parker 974 yesterday for $30 from a pawn shop but it is not even close to being as nice. If you make a collar post up what you do because mine is missing to!
Swan
Winona, MN
Thanks all, I really love this vise. I fabricated a collar tonight and it works well but does not look as cool as the missing original cast collar with raised letters "Parker".
I still am not finding any information on this model no 172 Parker vise. My welder friend and vintage vise collector believes it is from 1867 and the unusual swiveling static jaw was used for a few years only. Primarily because the design did not work that well. There is a removable pin (with new chain) that allows the static jaw to swivel to hold oddly shaped objects. Here a few images:
All done and ready for another 150 years of use.
Swan
Winona, MN
Can anyone please direct me to a website, source, book reference etc for more information on the history of Parker vises and tools? Thanks!
fivespdcat
Very cool vise. I unfortunately do not have any information to give except it looks like the dynamic jaw was replaced at some point and then filled to make it look better.
GETRIDAONE
Auburn, GA
http://www.dayid.org/mediawiki/index.php/Parker
You might stumble across websites that put old tool catalogs online for viewing. I found my model EE Parker on one of them. Parker probably made more models of vises than any other maker at the time. The whole town of Meriden CT was working at one of the Parker factories making all kinds of things back in the 1800's
kts
MD
Awesome restoration. Really makes me want to pick up an old vise and restore it.
Swan
Winona, MN
GETRIDAONE, thanks for the link, but alas, no. 172 on it. From that link I did see some vises have a spring tensioner to slow the travel of the handle. My vise has a threaded hole with a missing bolt at the end of the vise screw and this may be a spring tensioner.
Eric64
Awesome looking vise great restoration, I just picked up a Parker vise today at an estate sale it says Model 000 it has a rectangular slide and is a fixed base the date in the casting says May 28, Nov.26, Dec.10-17 1867 it has 3" jaws. Other than the paint being worn off it's in great shape no chips or dings. I was wanting to find out something about it. The little I did see about Parker didn't list any this old. Any info. would be appreciated. Thanks, Eric
oldldh
Fairhope, AL
Ya Dun Gud, Bubba!!!
Especially, considering that your vise is older than me...:evil::evil::evil:
And that is ancient!!!;););)
