Sis got me a computer from her work for the shop so I dont have to rely on my phone for music and researching. I tried to use my wifi card and i knew it, I got no signal from the house.
So I bought a 200ft ethernet cable from amazon for 13$.
Went to HF last night got me some goodies to mount my jackstands and gojax along with a 100ft fish tape.
Well my security system line runs in the one conduit to the house and I know it would be best to run my ethernet next to this instead of the power line to avoid interference. Well I thought it would be a simple task seeing how there was plenty of room in the conduit.
Sent down the fish tape, got it at the house and electrical taped the ethernet cable to it and covered all edges to not allow snags. Got about 25Ft down the 75 or so ft of conduit and hit a snag. Pushed and pulled a few time and got past it. but about 2 feet later hit a hard, very hard snag. Tried again but to no avail.
I pulled the fish tape as hard as I could, no luck. Tried to pull backwards lightly, no luck.
I knew i needed leverage to just bump it past the snag. Well i hooked it to my engine crane to slightly pull it. Started pumping slowly. Nothing. Wouldnt budge. So i kept going.....Started to pull pretty hard and then it budged! Success right? NO it was hard as a mofo to pull with the crane. Couldnt figure it out. So i kept going with the crane, readjusting the fish tape ever 2 ft or so. Then... BANG.
The fish tape now pulled out easy and with nothing at the end, but the spiral to hook cables too is now bent flat.
And my security was not working ofcourse... so i pulled that cable up to show that I stretched the hell out of it and broke the cables..
Went back to the house and pulled the ethernet through, End looked fine, had electape still on it. Well I looked at the security cable and it looks like it had a kink in it from when the PO ran it and it snagged the fish tape.
So I tested the ethernet and all but one wire tested fine... OF COURSE.
So kept trimming back and testing....till i found a whitened blue shielding on the ethernet. Cut it and checked there. Found the open.
Todays adventures will be to send the open ethernet cable along with a repaired security cable back into the garage..
Going to stagger and solder and heat shrink the security cables and put a new end on the ethernet ONCE its in the garage.
All this work for internet and music... What the heck.
