howdy,
i am building a shop that is 65x70 that will have 18' height for lighting.
i thought at first i would use metal halide high bays, but they are not instant on and consume some real big power. it would take 16 of them in the shop.
Based on which lamps/bulbs, specifically?
i have also looked at cfl acrylic high bay fixtures with 150-200 w high power CFL's (roughly equivalent to a 400w MH). i can buy the acrylic unit and the high power cfl for about $100 each. it would also take 16 of them.
Again, WHICH particular fixtures & CFLs? A quick search at 1000bulbs.com turns up these:
http://www.1000bulbs.com/product/8375/FC200-35871.html
But we have no idea what sort of fixture you would be putting them in; and that DOES make a differnce.
home depot has the lithonia 2' led high bay fixture for 200 bucks.
I presume you mean this one:
http://www.homedepot.com/p/Lithonia-Lighting-2-ft-White-LED-High-Bay-Light-IBH-11L-MV/203812710
comparing lumens on all these things is goofy and hard to gauge.
How so?
Per any number of sources (but
http://www.lightingtaxdeduction.org/technologies/high-bay.html is particularly handy), a 400W MH bulb will produce about 36,000 initial lumens. But as you are presumably aware, MH lamps lose quite a bit of output brightness over their normal lifespan; so, per the above-cited chart, the "mean lumens" figure is about 23,500 @ 40% of lamp life.
Fluorescent lamps lose only a relatively small amount of output brightness over their lifetimes (typically about 5-10%, max.); hence, they will still be putting out about 95% of their initial lumens @ 40% of lamp life. So using that MaxLite 35871 cited above as an example, given its 12,000 initial lumen rating, you could expect about 11,400 mean lumens. On a lumens/watt basis, this is roughly equivalent to the 400W MH lamps (tho' the MH types will do significantly better when brand new). But I am at a loss to understand why you think you'd still only need 16 of these CFLs to be equivalent to 16 400W MHs. Their per-bulb output is still only about half of the 400W MH; so by my abacus, you'd need approximately twice as many CFLs as MHs (which is not to imply that this is a bad thing, mind you).
Meanwhile, that Lithonia IBH 11L fixture is rated for "11,000+" lumens (the HD site says 11,200) with an "input wattage" of 149.8; but they don't really discuss the distinction between "initial lumens" and "mean lumens" (yes, LEDs
are subject to that same sort of degradation over their useful life; but I'm not sure about the degree, or how that compares to other types of lighting). Still, on a raw lumens/watt basis, this is clearly the most efficient of the lot. HOWEVER, we don't have any credible photometric data for either the MH or CFL fixtures you are apparently considering; so that could change things somewhat.
does anyone have any experience on comparing the cfl high bays to the metal halide and then has anyone put those home depot high bay lights in?
The above should be enough to get you into the ballpark.
HOWEVER... I am quite curious as to why any mention of LINEAR fluorescent lamps is conspicuously absent? In terms of simple cost-effectiveness, LFLs are sure to be your best bet, probably by a fairly wide margin. Compare the cost of one of those 200W CFLs with the cost of a standard-issue F54T5HO tube (such as
http://www.1000bulbs.com/product/90192/USH-3000397.html, for example.) Further, LFLs are also more efficient than either CFLs or MHs; that same standard-issue F54T5HO tube will put out more than 4,500 lumens, using only 54 (nominal) watts to do it.
And finally, there is a MUCH larger assortment of potentially suitable fixtures available, which means it will probably be easier to find something that permits the light to be distributed in an truly effective manner. In particular, your earlier mention of using only 16 fixtures (and "point-source" fixtures, at that!) to cover more than 4,500 ft.^2 of floor area causes big loud alarm bells to go off in my head: Even assuming relatively high mounting, that's likely to lead to rather "spotty" and uneven lighting.
Were it me, and pending the exact mounting height available, I would probably use something like these:
http://www.homedepot.com/p/Lithonia...put-Fluorescent-High-Bay-IBC-454-MV/202838871
http://www.1000bulbs.com/product/93811/BSS-HB4T5.html
http://www.1000bulbs.com/product/64991/PLT-TL5084T5.html
...and use enough of them to keep the fixture-fixture spacing down to the point where the resulting illumination is truly EVEN.
