spotco2
I know there are several here that have used these kits to build benches and really like them. Well, I needed to build a new bench so I thought I would experiment with one of these kits to see if they were everything they were advertised to be.
This is what I'm talking about in case some of you are unfamiliar with them
You basically but the legs and screws in a kit and just add whatever size wood you need to create a new piece of garage art.
I wanted to build one 8' long and 32" wide to fit a particular space. I used scrap lumber for everything except the top and I chose 3/4" CDX plywood for that. I wanted something hefty, so I used 2x6's for the top shelf and 2x4's for the bottom with 1/2" plywood for the bottom shelf. I decided to leave the middle shelf out so I would have more storage space on the bottom shelf.
Assembly took about an hour and was pretty straight forward. Just cut the boards and screw it together. I did have to use some bar clamps to square it up before installing the top, but that might have been the scrap wood I used or it might have been something to do with the plastic legs. Assembly took about an hour or so and I was not in a big hurry. The framing was all cut with a miter saw and I used a 18v impact to drive the screws in. I liked that the screws for the legs went in at an angle to pull the wood into the corners tight.
With 2x6's on top and 3/4" plywood it came up to a nice height of 37" tall. That was very comfortable for me at 6'-2". I actually used it for scaffolding to stand on to work on my lights this afternoon, but it was heavy to slide around and I wanted to make it more mobile.
The bottom of the bottom board is about 3 1/2" from the floor so I needed 4" casters to get it up to rolling height. Off to Home Depot I go and come back with 2 rigid and 2 swivel 4" casters with brakes.
http://www.homedepot.com/p/Everbilt...aster-with-Brake-49512/203661087#.Un663uJin_E
http://www.homedepot.com/p/Everbilt...gid-Plate-Caster-49484/203661071#.Un66e-Jin_E
Flipped the bench on it's top and scabbed on a 2x4 inside the bottom shelf to give me enough room to bolt on the casters. This raised the legs up about 1 1/2" from the floor and the work height to about 38 3/4" which still works well for me, but shorter folks might like it better with a 2x4 top instead.
Overall I am very happy with the end result. The bench is extremely sturdy and it now glides anywhere I want it to go. I know y'all like pics, so here's a few before it gets trashed in the shop.
