Wet/dry vacuum comparison. Ridgid, Shop Vac and Craftsman initial review -PICS-
SMKS
USA, planet Earth
I already have two shop vacs, a small Stihl shop vac for general cleaning in the car and garage and a larger Dustless Technologies Hepa vac for lead paint and other fine debris.
I’ve been wanting a larger, moderately priced vacuum for sucking up water and general messes that may be too much for the Stihl. I picked up these three and compared them to see which one I like best.
A note on suction:
All these vacuums seem to have good suction, with some variation from my casual testing. My “test” involved sticking my hand partially over the end of the hose to judge the suction.
Frankly, any of these vacuums provide more than enough suction for my needs, and actually too much for some jobs. So, I didn’t do any tests to see how fast they pick up debris or water.
Since any of these will meet my needs, I’m comparing them on noise, build quality and the quality/quantity of attachments.
A note on noise:
I’m not claiming this is a scientific test, so I would encourage the GJ members who always claim “that’s not scientific enough” to save their breath and complain somewhere else. I’m only providing this info to try to show some kind of quantifiable difference in the sounds volumes.
I used an app for my phone to measure the decibels under similar conditions. I plopped each vac into the middle of an in-progress project in my basement, then measured the decibels from seven feet away. I even went as far as to make sure the hose was pointed the same way on each vac because I found pointing the hose end at the phone would increase the db reading.I even introduced some variables, such as switching the positions of the vacuums and the difference in dB ratings stayed pretty similar.
What my experience with these vacuums shows is that there’s more than just pure decibels to consider. For example, the Craftsman produces nearly as many decibels as the Shop Vac in my “testing,” but the noise produced by the Craftsman seems far less grating to me. The Ridgid WD1450 is 4-6 dB lower than the Craftsman and Shop Vac, which is significant, but the type of sound produced also seems more tolerable.
Here's where I did the sound testing:
A note on calling this a “review”:
I’m only judging these vacuums on noise, the attachments they come with and build quality. Those are by far the most important qualities to me. I can’t comment on the long-term durability since this is only an initial review.
I’m sure there are other models people would recommend, but I searched through what was available locally and these are the ones I picked to try out.
Ridgid WD1636 16 gallon purchased at Home Depot for $40 on Black Friday
(no pics of this model because I forgot to take them)
http://www.homedepot.com/p/RIDGID-16-Gal-5-Peak-HP-Wet-Dry-Vac-WD1636/204351678#.Up4pieLvZOI
COO: Mexico
Approximate decibels:93- 95
Warranty: Ridgid claims this has a “lifetime” warranty against manufacturing defects.
Pros:
-Cheap
-Big
Cons:
-Really low-quality hose. It’s cheap, stiff and plasticky. Definitely the worst hose of any vacs I’ve owned or used.
-Short hose. I’d like longer than seven feet.
-Really loud.
-Very poor assortment of attachments. Cheap paper filter and only one adapter.
-Jet-like exhaust port. A really powerful jet of exhaust goes straight out the back of the vac and will easily blow around anything in its path. You can buy a diffuser for $13.
Other thoughts:
This is a de-contented model specifically made for Black Friday sales and I was not impressed. By the time you buy other attachments and a better hose you’ll have spent enough that you could have just bought a better quality and better equipped vac in the first place.
If all you want is cheap and big, and don’t care as much about noise or attachments, it’s probably not a terrible choice.
Shop Vac 5876200 12 gallon purchased at Menards for $79.99 after MIR (regularly $129.99)
http://www.shopvac.com/wet-dry-vacs/vac-details.aspx?vacId=399&vacSKU=587-62-00
COO: “Made in the USA with foreign and domestic components”
Approximate decibels: 90-91
Warranty: Four years in home use
Pros:
-Really nice selection of attachments, by far the best of this group. Good non-paper filter that can be used for dry or limited wet pickup.
-Nice quality hose. It’s 10 feet long and much more supple and flexible than the cheap Ridgid’s hose. It’s still more soft and flexible than the Craftsman or WD1450 Ridgid.
-Somewhat diffused exhaust. There are two smaller ports that diffuse the exhaust back and somewhat down, but it will still blow stuff around.
-The cart and big wheels could make transporting this vac easier than other models.
Cons:
-Loud. Shop Vac rates their vacuums on a scale with words like “quiet” and “super quiet.” This vacuum is rated “super quiet,” but on first blush I thought this vac was really loud and the noise is very grating. The interesting thing about this vacuum is that most of the noise seems to come from the exhaust. If they did a little sound control on the exhaust it might be a big improvement.
-Heavy because of the stainless steel tank
-Cheap feeling on/off switch
-Head to tank connection seems the loosest of the three.
Other thoughts:
On paper I thought this would be a sure winner. Quality attachments, a long hose and claimed “super quiet” performance looked like just what I wanted. I was disappointed when I plugged it in and heard how loud it is.
If I didn’t care about noise as much, I’d choose this vac.
SMKS
USA, planet Earth
Craftsman 12006 12 gallon purchased on sale for $66.29 at Sears
http://www.sears.com/craftsman-xsp-12-gallon-5.5-peak-hp-wet-dry/p-00912006000P
COO: China. Craftsman vacs used to be made in Mexico, but the new models they released recently all appear to be Chinese. By comparing some details, it appears the new models may be made by Vacmaster.
Approximate decibels: 88-89
Warranty: One year
Pros:
-Good selection of attachments, but not as good as the Shop Vac.
-Decent on noise. The noise produced by this vacuum seemed significantly more tolerable than the cheap Ridgid or Shop Vac, even though it was only a couple decibels lower.
-Least expensive of the well-equipped vacs. It seems like a bargain.
-Power switch and head-to-tank connection seemed fine.
Cons:
-Hose is only seven feet long, but it’s less stiff and more useable than the cheap Ridgid’s hose. It’s on par with the WD1450 Ridgid and not as nice as the Shop Vac.
-COO is China, if that matters to you.
-Single jet exhaust port. A diffuser is available.
Other thoughts:
Unlike the cheap Ridgid, this isn’t a de-contented model. It’s just one of Sears’ normal models that’s on sale for the holiday season. For an extra $20 I could step up to a 16 gallon model that’s otherwise very similar to this model.
For the price, I’m pretty impressed with this vacuum. It seems to offer a lot of value.
SMKS
USA, planet Earth
Ridgid WD1450 14 gallon purchased at Home Depot for $89 (regular price is $99)
http://www.homedepot.com/p/t/100081216?storeId=10051#.Up662uJVNNI
COO: Mexico
Approximate decibels: 85-87
Pros:
-It produces the quietest, least grating sound.
-Second largest tank after the cheap Ridgid.
-Decent selection of attachments and a decent filter.
Cons:
-Seven foot hose is shorter than I’d like, but it’s not nearly as stiff and difficult to use as the cheap Ridgid.
-Most expensive.
SMKS
USA, planet Earth
Conclusions:
None of these seem to be bad vacuums, in my opinion, except for the Black Friday special Ridgid. I think the choice comes down the the specifics you personally want in your vacuum. For me, a vac that’s moderately quiet will be easier for me to use and I’ll be more likely to use it.
Here’s how I would rank these specific models:
1st - Ridgid WD1450. It’s the most expensive and it has a short hose, but in the long term the quiet(ish) performance is what I’m looking for.
2nd - Craftsman. This is a really close second. It’s really well priced, well equipped and pretty quiet. If it had a longer hose it might very well be my top choice.
3rd - Shop Vac. Great selection of attachments but hampered by what I consider grating, annoying noise. If you want to use this in an environment where some extra noise doesn’t matter, then this is the clear winner based on its attachments and long hose.
4th - Cheap Black Friday Ridgid. It’s cheap for a reason. It’s loud and poorly equipped, but it is big and really affordable. If that’s what you want, this is the vac for you.
oldldh
Fairhope, AL
I'm going to get a shop vacuum fairly soon, and your "Road Test" helps narrow the field...:thumbup::thumbup:
I appreciate your efforts...
I know someone's going to say you really, really ****...:evil:
But I won't...
SMKS
USA, planet Earth
I had looked at the CFM ratings of these vacs before buying them. But a member of another forum noted that the Shop Vac is rated at 390 CFM, which is nearly twice the other models, so it must perform better. This didn't jive with my casual inspection and use of the vacs.
Just for anyone else who notices this, the 390 CFM rating for the Shop Vac appears to be a typo. It looks like they accidentally put down the air watt rating (390) as the CFM. If you look at very similar Shop Vac models they're rated around 200 CFM.
Taking that into account, the CFM ratings would be:
-Shop Vac 200 or so
-Ridgid WD1450 168
-Cheap BF Ridgid not listed
-Craftman not provided
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
This is a super nice comparison. It would be nice to be able to rate the "suction power" as well though, not just the noise. Some are surely better than others. Maybe fill up a 5 gallon or 10 gallon tank with water and measure the time it takes each to drain the tank. That would be a simple way to do it or a tank full of sawdust too.
Over BF, I picked up the $50 Shop Vac 5.75 hp 16 gallon one at Lowes. That isn't in this comparison. It is powerful, has a pretty short hose too (6 ft maybe?), and also fairly loud. I chose it over the Rigid BF one and glad I did. I've had super good luck with Shop Vacs over the years in smaller sizes and consider them great value for the money. You can also get parts for them. I did have to replace a switch on one of them for about $8 once. Also, any vac will do 100% better sucking with a dust bag in the tank or around the filter as your type may dictate. Any muffler could help quiet one down too.
On noise, it is known that humans like more harmonically ordered noise and less disharmonious or "rough, scratchy" sounding noise, even if both are at the exact same db level. Humans will perceive the rougher sounding noise to be much louder and annoying. This comes from high fi amplifier and pre-amp kind of development for music gear, where the absolute level of harmonic distortion is somewhat less important than the "nature" of the noise in the electronics. This is only becoming understood over the last 10-20 years gradually. For instance, vacuum tube amps and pre-amps always measure with very high noise levels compared to transistor amps, but many people much prefer the sound of vacuum tube electronics over transistor electronics due to the more ordered and harmonious nature of the noise present. The highest cost electronics are the tube based today. I'm talking about gear that might cost several thousand dollars a component, super high end stuff. Old 20-30-40-50 year old Marantz or Macintosh tubed gear today commands very high prices used and is kind of like vintage cars this way. We didn't know what we already had way back when before transistors took over in the 60's, 70's and ever since. - Paul
SMKS
USA, planet Earth
I had my wife try out all three vacuums to judge the noise. Here's her very unscientific judgement:
-Ridgid: "I like this one best."
-Craftsman: "It's OK."
-Shop Vac: She just frowned and shook her head when she turned it on.
beamrider
Columbus OH (displaced from Wheeling)
Get a 55 gallon drum, or a 5gallon paint bucket if you need something smaller, and make a Thien baffle for it. You'll be surprised at just how much debris doesn't make it into the filter. A cheap plug in muffler on the exhaust port will cut the noise ~20-25%, makes it much more manageable.
SMKS
USA, planet Earth
The building I work in has been under renovation for about the last decade. I've been noting the brands of wet/dry vacs the construction workers use.
My informal survey shows:
-80% Ridgid
-20% Shop Vac
Danglerb
SoCal
They all **** and are noisy, what I have noticed, and I don't mean to pick on Craftsman, its just what I have.
How well do the hoses fit on attachments other than those that came with the vac?
Do the Fing wheels come off all the time, like from picking it up.
Do the filters last, how easy is it to dump.
WVBrady
WV
Does anyone have an attachment for these that has a brush for picking up dust off the concrete floor? All I can find are the hard plastic ones that just scrape along, a little like fingernails on the blackboard. The standard filters aren't much good for fine dust either, but you can get a (rather expensive) special "drywall dust' filter for that.
p.s. Thanks for the review!
cheechi
Triad, NC
I have a Ridgid vac with similar or the same hose as yours. It is 'harder' plastic than some others, but that thing has taken plenty of abuse in the past few years and is still strong. half the time I tie it in a knot to store it. No leaks or breaks.
boiler7904
NW IN
I've had the WD1450 for 8+ years and have no complaints with it since I bought a CleanStream filter and an aftermarket hose.
It's sucked up more sawdust than I care to recall, cleaned numerous cars, and even used to de-water the hole for my patio project after a 2" rain.
The only feature that I'd like is a power tool activation like what power tool manufacturers are now offering on their more expensive units.
ajchien
Los Angeles, stuck on the 60 freeway.
One thing I wold ask, can you compare the wheels on these vacation and how well they roll, and how well they roll over cords, carpet etc?
No matter how long the hose is, it's always a little too short. I wind up pulling my vac across the floor - and sometimes without me noticing, it's fallen over as it tripped over a cord or something...
e-tek
Saskatoon, SK
Must be a ShopVac thing. The suction was always amazing - especially for such a small unit, but it was SO friggen loud - and grating - that I hung a pair of dedicated hearing protectors on it and sometimes used them in addition to ear plugs!
Josey Wales
Tacoma, Wa
Your science is strong. Proven over thousands of years.
I picked up the WD1450 based on this review and like it a lot. Still made in Mexico, and still quiet.
honcho
Near Sodom & Gommorah (aka Wash. DC)
I have a 12 gallon Craftsman purchased in 1987, 1 16 gallon ridgid purchased in 2001 and a 5 gallon wall mountable Shop Vac purchased in 2004. All ****, all are noisy and I'd buy any of the three of them again. I believe both the Craftsman and Ridgid were manufactured by Emerson electric. I'd like quieter units, but a bit of hearing protection is a lot cheaper than purchasing a quieter and much more expensive Fein or Karcher vacuum.
Kev442
Wi
I've bought all three brands, but in different sizes. But I can still give my unscientific opinion.
Bought two Shop Vac 12 gallon's on sale for about $65 each back in 2001 or so. Extremely loud yowling noise that would drive anyone insane in mere minutes. The unit seeing the most use flamed out, literally. The brushes gave up and sparks approaching flames came out of it. Was not impressed. The second one is used occasionally, but I avoid it.
I decided to take a flyer on the Cman $29.99 special 6 gallon. I wanted something portable but still able to do some serious vacuuming once in a while. It does exactly what I wanted. I now have one in the garage and one in the basement. Much quieter than the Shop vac with a lower tone.
The Ridgid was needed at work. 16 gallon with the larger diameter hose. $99? on special. This is the real deal. Anyone with daily vacuuming needs is gonna be happy with it. The tone is mellow and it can ( and has been) run for a hour or two straight until full, emptied and done again. If you want to try and test the warranty and use it for dust collection on your saw, go for it. I much prefer a real dust collector myself.
