is an asphalt garage floor any good?
Bib Overalls
Jonesboro, Arkansas
Never seen that.
Asphalt is a good surface for parking cars. It is not particularly suited for shop flooring.
If the asphalt is problematic or if you have more ambitious plans for the space then it may be time to replace it with concrete.
Of course, it is not that simple. You need to factor the cost of the improvement and it's effect, if any, on property values, the length of time you plan on being in the home, and the benefits you are expecting. Upgrading to concrete may or may not be a bad business investment but you also need to factor in the intangibles. If concrete makes the space more adaptable to your purposes and expectations then that alone my justify the expense.
MeentSS02
Dayton, OH
Asphalt doesn't do a good job of handling point loads like jack stands...I've had jack stands sink in asphalt before, and I can't say that I was a big fan (this was a parking lot though, not a garage). It'd likely be fine for parking, but not for much else.
Highlux
Ofallon, MO.
Terrible idea.
To have a blacktop anything.
They ruin flooring in the house from oils that get in your shoes...
allinon72
Indianapolis
It's not good for anything but parking a car on. And even then it's marginal. I have an asphalt driveway and sank a jackstand about 3 inches into it :lol_hitti
CNGsaves
KS and OK
Let's SEE what you're working with, as it's very unusual to have asphalt inside garage.
Dan in Pasadena
Pasadena, CA
If you ALREADY have it, it's in good condition (or only needs a slurry coat) just keep it. Use a 12x12 square of plywood under jack stands of floor jack, but otherwise why spend thousands on demo & replacement?
KPSquared
Wetaskiwin, Alberta, Canada
If you can live with it, then why not? I'm guessing this was a car port or something before it became a garage? I've never seen asphault in a garage.
WE WANT PICS!!!
H
henrys103
currently exiled in NJ
Never seen that.
no,no this is at my house,, not a business
Jay H 237
Torrington, CT
I've only seen asphalt for a garage floor once, it was a house a friend bought. The attached (by breezeway) garage was added later. The original owner built the garage right (poured footings and foundation) but ran out of money once it was enclosed and it lacked a floor for awhile. When they had someone come to redo the driveway they decided to run the asphalt into the garage too.
It was OK for what it was used for, keeping a car there and better than the dirt floor. They didn't do car work in there so I can't comment on how it would hold up for that.
garboui
Southern Ontario
If your parking the tracks from the tires will slowly create divots dust from driving over. This will now make sealing at the bottom of the garage door problematic as all sorts of critters will be getting in.
