Building code book for dummies???
Zogman
So. Cal
Starting my construction of my garage as an owner builder here in So. Cal. I will be farming most of the work out but will also be doing a bunch myself. Any books out there that y'all are aware of that provide a novice as myself guidelines on building codes for construction? Thanks
Zoli
Cyberbear
California
I, too, am located in So. Cal. and before getting too involved with the legalities of being an owner/builder, did some Online research regarding what actual jurisdiction the local code enforcement people really had over me and my property, you may be surprised if you do your own research. Most private property owners have been conditioned into believing applying for and receiving a permit is absolutely necessary, but Calif. history shows otherwise.
LigouriRd
Glendale Heights Il.
In addition to what was mentioned above about local codes I would recommend Black & Decker Codes for Homeowners. It is based on the International Residence Codes for 2014.
72Anthony
Houston, TX
Check out the Code Check series. They have a lot of illustrations and point out common issues. They are no means a substitute, only a very brief summary. A good place to start and you should get the full version of the code as reference.
cmoist
Lebanon, OH
I actually got a copy of the for Christmas. Some good info in there.
Moose97
North Central Texas
Go to the ICC website ( iccsafe.org ) and get the book "Building Code Basics - Residential" . Talk to your local Building Official. Tell him what you are wanting to do. You may be pleasantly surprised at how helpful he can be. Tradesmen and builders generally make the same mistakes over and over. He might help you out with general problems he runs into. Framing should be hired out in California to a pro due to the seismic building requirements. All other work (in Texas anyway) can be done by the homeowner if the property is "homesteaded". You are still required to meet all codes, ignorance is no excuse but I would rather someone be up front and honest with me than try and get something over on me. We can avoid sometimes costly problems that way.:thumbup:
DekeT
USA
Yeah, you go with that then. If must be true if you read it on the internet. :lol_hitti
boiler7904
NW IN
Look at your local Building Department's website or ask them specifically which codes they use so you can get books or other information that matches the enforcement. You also want to know if they are in the process of updating their enforcement and when the change would go into effect. If they change codes the day before your design is submitted, you may have to make design changes to meet the newly adopted code. I've had commercial projects that required design changes because a new code or requirement went into effect between permit application and permit issuance - that's always fun. No point spending the money to comply with 2012 code if 2003 is being enforced unless you want to out of personal preference.
You need to know what local amendments to the codes have been adopted in your town or county. Local authority always has the ability to delete provisions of a code to make it more stringent. By law, they have to make the actual code and any amendments available to anyone that requests it. This may mean a public copy that you have to review in their office or a download on their site.
The IBC and IRC are available to view online for free - can't remember if you can download them or not. You should also be able to find all of the other International Code Series too.
Another good source of information are websites such as municode.com which acts as a library of all laws for towns that are part of the service. Municode is just one example - there are others if you look for them.
Z
Zogman
So. Cal
Thanks guys. Great information. At least I have a direction to go with now.
