"Converted" my Ridgid impact driver to square
FriendOfYours
Ridgid offers nearly everything I need, love the warranty and have had good luck with their tools. But, the only thing they don't have is a 3/8" impact wrench. They have a 1/2" but it is much larger
Pulled the hex drive and milled it to a 3/8" square anvil. There is still quite a bit of meat between the hex hole and outside
Who knows how long it will last, but the arbor is replaceable so I can always order another and weld the hex. I just need to machine a groove for a friction ring
Voi
Western South Dakota
Who knows how long it will last, but the arbor is replaceable so I can always order another and weld the hex. I just need to machine a groove for a friction ring.
Nice, I was wondering who was going to try this first. Are you going to try to use this as both a 3/8" wrench and 1/4" driver? But if it fails you'll order another arbor and fill it with weld before machining it down to 3/8" hex?
F
FriendOfYours
Yes. Once you detach the arbor spring lock thing, it just falls out. No messing with the actual motor itself
Good solder joints and everything hot glued in place.
I have a Hitachi brushless 1/4", so the Ridgid will be just 3/8". I talked to the Ridgid local repair guy and the replacement arbor is only $15, and ya, I'll fill the center in and machine it
taumac
Brooksville, Fl
Got a question... Wouldn't these be easier? 1/4 3/8 1/2 I use all of these in my 18 dewalt impact.
dfreeman616
Grand Rapids, MI
The downfall to those adapters, and why i got a 3/8" to round out my tools, is that they add length to the driver as well as reduce the final torque at the fastener. certainly better than nothing, though.
taumac
Brooksville, Fl
I can surly see length could be issue a issue but didn't know about reducing torque. I know that I'm looking for a small right angle impact to add to the collection someday.
F
FriendOfYours
The Ridgid JobMax is awesome for that. Can have right angle and a 3/8" electric ratchet
He's right on the money though. From just testing here I lose !at least! 25ft/lbs using an adapter and it adds a good 1.5"
I know that sounds like a lot but the extra leverage of the bigger anvil makes a huge difference. Good example is to compare the Milwaukee M18 line. The 1/4" makes significantly less torque than the 3/8", and the 1/2" is 10ft/lbs more than the 3/8". Exact same guts, different anvil
Kracin
Omaha, NE
Have you ever actually tried to use the Ridgid warranty yet?
i was wondering about their warranty as well, it sounds really good until you read it all the way through and they basically just cover defects for life, not when something gets worn out. if you don't find a defect in 3 years of use, there probably isn't one. so it makes the lifetime thing somewhat null and void.
that and apparently you can only purchase ridgid through an authorized dealer (home depot), if you buy through amazon, they won't accept your warranty
F
FriendOfYours
I've warrantied a sawzall and my original jobmax. No hassle, you just have to make sure you register right when you buy them
tcianci
Walpole, Ma
I have Ridgid 18 Volt Li stuff. I have used the warranty several times, batteries, chargers and they have rebuilt the reciprocating saw twice so far. I am a contractor and have used most of the cordless brands out there. Ridgid is not the best but so far it has the best warranty.
Voi
Any updates on this?
