Dow Thermax Insulation Sheathing not sold at the big boxes stores
harvero
Flemington, NJ
So does anyone have any idea why Thermax is not carried by HD or Lowes? The 2 inch thick sheets are R13 and are fire rated for interior installation without the need for 1/2 sheet rock for fire protection. The sheets come with a white finish and seem like a unique option for insulating a basement wall without having to hang drywall.
THERMAX™ Sheathing is a nonstructural,rigid board insulation with a glass-fiber-infused polyisocyanurate foam core laminated between 1.0 mil smooth, reflective aluminum faces. The glass-fiber reinforcement provides improved fire performance and dimensional stability. THERMAX™ Sheathing can be installed exposed to the interior without a thermal barrier. THERMAX™ Sheathing offers high, long-term R-value. Used in conjunction with the appropriate joint closure system, THERMAX™ Sheathing with its low perm rating helps to reduce moisture condensation within and behind the insulation.
THERMAX™ Sheathing is specially designed to have a Class A fire rating and can be used in a range of concealed and exposed applications, above and below grade, and can be used in exterior walls. Because of its improved fire performance, THERMAX™ Sheathing is especially appropriate for hourly rated assemblies.
THERMAX™ Sheathing is approved for use, per Section 2603.5 of the International Building Code, in Exterior Walls of Types I,II,III and IV construction. THERMAX™ Sheathing is designed for use as
continuous insulation in both interior and exterior applications to assist in meeting and exceeding both the
most current IECC and the ASHRAE 90.1 energy standards. Maximum length is 30 ft. (9.1 m) and maximum
thickness is 4.25" (108 mm).
So what's wrong with this stuff, other than it is a bit pricey?
H
harvero
Flemington, NJ
The polyisocyanurate sheets that lowe's (rmax) and HD (DOW Tuff-R and Thermasheath) sell state that they require 1/2 drywall installed over them when used on interior walls.
Mr onetwo
Coastal Maine
I asked my local lumber yard for a quote for Thermax white face and was told that all those products have been discontinued.
crankshaftdan II
Milwaukee, burbs.
I used some of this in a un-covered area-when you have any tempature differential it has a tendency to off-gas the formaldhide that is used within-smells nasty! Just my two cents worth!
hand
Home Depot was able to put together a Dow Thermax quote for me a year or so ago even though it wasn't listed on their website.
ruffryder
Just found that there is another option instead of Dow Thermax, Rmax sells a TSX-8500 that appears to have similar properties as the Dow Thermax.
