JimmyTheMonkey
This was in my kitchen nook, not my garage, but y'all are so knowable, I am sure someone here will know the answer.
Through a combination of my lack of experience with TSP and very inadequate instructions on the box, I let TSP dry on the walls for around 30-60 minutes before rinsing the walls with water. I was not aware the TSP had to be immediately washed off. I looked around on the internet for the consequences of this mistake, but the only thing I could find was an "ehow" website that said letting TSP dry on the walls will make it even harder for paint to stick.
The walls are currently covered in a cheap coat of oil based paint (previous owner) and the trim/beadboard is covered in a 8 month-old oil based Kilz. I washed everything with a TSP solution first and then went back 30-60 minutes later and sprayed everything down with water from a spray bottle and wiped down with a cotton rag. I plan on eventually coating everything with 1 coat of 123 Zinnser latex primer (hence the TSP) and then 2 coats of SW latex.
What should I do to ensure that the new paint sticks? I was already thinking of sanding everything with 150 grit, but I will definitely do that now. Any other suggested steps because of my primer mishap?
