Mongo Blasting Cabinet
OccupantRJ
Eastern North Carolina
This is a suction type blasting cabinet I bought from my salvage yard friend years ago and restored right before my shop was flooded out. I paid $150 for the unit, with the promise that I would repair it and get it in operation.
The main cabinet was stored on it's door in a low spot in a roofless warehouse in a couple inches of rain water when I found it. Had to have it, wiped off the drool from my chin and made the deal.
After getting the unit home, I set about to repair the extensive rust damage to the end of the cabinet. I had to cut out the door end of the cabinet, fabricate and replace the end panel, and fabricate a complete new door for it.
The aluminum panel on the front of the cabinet originally had a one inch mat of foam sound deadener behind it to knock down some of the noise. That had rotted, so was removed until I can obtain some more for it. There is a air wash intake at the top near edge of the cabinet for ambient air intake when the reclaimer is running, and serves to wash the viewing glass with air for better viewing and to prevent glass erosion.
Right after I got through with the unit was when the flood hit, so after draining the cabinet and rinsing it out, it was moved and stored in my storage trailer until life turned around a little.
To make things easier in using and servicing the unit, I fabbed up an angle frame dolly with the cabinet, filter baghouse, and cyclone separator welded into it to make a modular mobile unit. The system now resides in my present shop, and just got piped up with my new air piping system. See
http://www.garagejournal.com/forum/showthread.php?t=227948
The pics were taken during the move from my storage trailer located about 20 miles from my shop. That's a 4 x 8 trailer it's in.
Strouty
Southern Maine
Is your forklift stuck? If not how the hell did you manage to drive on the grass and not get stuck? Nice cabinet!
O
OccupantRJ
That usually can be a fairly wet area, so I caught it during a dry spell. I drive a forklift daily during my maintenance job duties, so I have learned what I can get away with. If it ever spins, you're through. I keep a steel plate at the rear of the trailer to load or unload on there. There was also a 35 hp diesel tractor just out of view if needed.
Packard V8
Spokane, WA
Looks very much like the one in the engine shop where I do my work. Who's the manufacturer of yours?
jack vines
O
OccupantRJ
jack vines
That is something I would like to find out. There is no ID of any kind on it, and I have searched google images to no avail. The baghouse and separator are Cyclone brand.
O
OccupantRJ
Was just blasting the door to a 20" Delta bandsaw just then when I noticed how much room there is in that sucker, so decided a pic was in order. That is the door along with a 15" wheel in there. I had left the wheel in there while blasting the door. The cabinet is 4 feet x 3 feet x3 feet.
O
OccupantRJ
My son came over tonight to blast the upper dovetail ram from his Bridgeport. It was so heavy we had to load it into the cabinet with the forklift. It looks a little lost in there, and it certainly is not a small part. We used aluminum oxide with 100 psi while flowing, with a 1/8" air jet.
