Recommendations for mounting hose reel to finished wall
NewEdgePerf
What is the best way to mount a hose reel to a finished wall (drywall)?
Thanks in advance for any help you can offer.
Tony D
larry4406
Northern Virginia
I mounted the Task Force brand hose reel from Lowes on the ceiling. Similar to the HF brand.
The mounting base has two slotted/open bolt holes and two thru drilled holes for 4 point mounting.
I had put 2x10 solid blocking in my ceiling prior to drywall. Holes were marked and pilots drilled.
For the slotted/open holes, I used lag bolts and washers and put them in place leaving about 1/4" gap between the washer and the ceiling. For one of the thru holes, I used a lag bolt with a threaded end with washer and nut. This method allowed me to quickly heave-ho the real up to the ceiling, slide the slotted holes in place, and then spin a nut with washer on the stud to hold the real in place. I then put a normal lag in the last thru hole and then tightened all down.
With a 12' ceiling and by myself, this was the best method for me. Hope this helps you.
1938flatty
I used 3/4" plywood lag screwed to two trusses. Before I mounted the plywood I laid out all my reals and put carriage bolt down thru the wood. Installed the plywood to ceiling, put reals in place and tightened nuts to the bolts. That was the easiest way for me.
Good luck. :thumbup:
marsh1
Texas
I used Unistrut for hose and cord reels
