looking for carriage style door ideas
3/4tonYJ
Central, PA.
I've got my 22 x 12 lean-to addition under roof and been planning on building some carriage style doors, but not sure how I'm going to mount/add windows/use vinyl siding etc.....
I framed opening as large a I could, would like to make doors wide enough so I can back in car trailer.
here's were I'm at now, any ideas?
View media item 38714View media item 38715
Ross/Kzoo
Richland Mi.
If I'm understanding you correctly why don't you make the carriage doors like a swing gate? Framed with 2 x 4, sheathed with plywood and use tension cable on the diagonals to keep them from sagging.
3/4tonYJ
Central, PA.
Yes and No, I don't want to build the doors like you described, but it's the only idea I have currently. (maybe make them arched with the left side being a separate upper and lower halves, so I can open upper for ventilation or something) below is the doors I made already, they are flush mounted to allow the large sliding door to be slid over them)
View media item 38720
this is my current design: but I want something alittle more creative.
View media item 38721
gregtwojeeps
Ky
May want to incorporate some type of rain flashing over the doors. The lack of gable overhang is going to allow water to permeate the top of your doors.
Ross/Kzoo
Richland Mi.
You've got to be talking big $$$$ for a custom door like that, definately more than you have in the rest of your lean-to.
65BCUDA
Eustis,FL
Off topic ..........Am I seeing your OSB on the rear wall not breaking on nailers?
I would think over time there may be some bulking issues...........
3/4tonYJ
Central, PA.
Yes, that's a great idea. I think I could make slightly decorative and use up the leftover metal roofing.
I'll be building these doors myself, I've built this complete garage including both sliding and smaller carriage style doors. here's a link to my build thread (having issues with signature) http://www.garagejournal.com/forum/showthread.php?t=5883
good eye, I plan on making some build-in shelving on that back wall. it will cover seems and firm up back wall.
3/4tonYJ
Central, PA.
looking for framing ideas also, possibly set back a few inches but still opening out.
i'm happy with other pair off carriage doors I built, just want a different style, and I can't really think of anything
mustangsean
Pottsboro, TX
These are much larger, but my own design -
[/URL][/IMG]
Zeke
If you google "carriage dutch doors" you'll see a few and if you delete dutch you'll see a bunch. And then if you add "house" in lieu of dutch it gets better. Now if you use european, antique and western, etc. as modifiers, you'll see a few fresh hits on each search.
You have to work at this, man.
