Just wanted to share this with you, it’s made my compressor and I much happier.
I’m sure most of you already have something similar, but up until a short awhile ago I was just using some cut-outs from old mud flaps to help with vibration.
While cleaning up around my compressor I looked at the pads and thought I really need something thicker, something that will absorb better.
So, I did a little research here on GJ and found this Idea from floyd
I thought what the Hell, went to Home Depot and picked up the set.
To my amazement, these pads work great! The compressor seems to like them just fine. It’s actually quieter than before.
The pads measure 3 ¼” square x 1 ¼” thick. My compressor’s rated weight is 648 pounds. I did not bolt it down; it’s just resting on the pads. They are carrying the weight just fine, the compressor is stable and it has not budged whatsoever.
Sometimes a little research does payoff.
Needless to say I’m very happy with this arrangement, thanks floyd!
