New Floor (pics) Versatile Building Products
mcave
Actually this was done 2 years ago. I asked some questions on this post but never followed up until forum member DoItMyselfToo contacted me on details. I thought that I'd just post up.
I was looking to do it myself, but decided to get quotes to see how much it would cost. The Roll on rock kit would have run $500. A diamond grind machine would have run another $100+. I received several quotes and went with the lowest at $800, around $2/sf for my 400sf garage. I thought it was a pretty good deal considering labor was really only $200 more than it would cost to do it myself.
The contractor was supposed to use the Roll On Rock kit, but ended up using the 5325 urethane instead of the 5073 polyurea. He claimed that the 5325 was tougher but was more toxic when curing (I told him I worked on cars and also wouldn't be moving in for another 2 weeks). I also think it was cheaper for him. He did some patching, grinding (diamond?) before rolling.
Despite several members' advice to put in grit, I simply could not get myself to do it. I really didn't want to slide underneath my cars on a gritty surface when working on them. As a compromise, I put in flakes for some traction when wet, and I think I made the right choice. We don't get a lot of rain here in CA, and I haven't had any problems. Even when wet, it's not that bad. Just need to be careful when I wet clean, which I only do several times a year.
Pics ...
mcave
Close-up showing texture
SunsetsAndFriends
mcave - floor sheen looks very even from the photos. As for the texture, it appears from the photo that flake was applied. I cannot see the flake color variation that well. Was a multi colored flake used? A picture to show the flake a little closer and color would be nice.
How has the finish held up for you? Any big complaints or issues with the installation? How much fume did the 5325 urethane clear coat give off?
Thanks.
DoItMyselfToo
mcave
I purposely chose a flake color that matched the epoxy undercoat. I wanted a clean look like a laboratory but with some texture for when it's wet. The downside to that is that dirt is very obvious compared to using multi-colored flakes. The photo on my second post is pretty much what it looks like - you're not missing anything. The flakes are 1/4". Dark grey flakes, lighter grey undercoat.
That urethane top coat - let me tell you - that stuff is down right toxic. I don't recommend it unless you are sure you can completely seal off the door opening cracks into the house. I think the polyurea in the Roll on Rock kit out-gasses much less IIRC.
SunsetsAndFriends
Ok. I see now. I thought I might not have been seeing something that I should. Cool idea.
I figured the urethane would give off a lot of fume. Does it seem very durable?
mcave
When I look closely at my floor, I see little holes and scrapes caused by dropped tools, jack stands, etc. There is also a spot where the urethane yellowed a bit from when one of my cars dripped oil and I didn't clean it up for maybe a month or two. This is my first epoxy floor and, honestly, I expected it to be a little more resilient against damage and discoloration. I don't have experience with anything else as a reference - hope this helps.
SunsetsAndFriends
Thanks for sharing, mcave. Sounds like you really use your garage. Cool.
