Rhyno
This failure is caused by water and "Management" decisions to not use a lot of grease. The bearings are probably, chinese, too.....
Anyways......
On my 42" twin blade mowing deck, there has been some "SCREAMING" going on. I knew it was a bearing starting to fail. I thought that it was the blade spindles and bearings.
Last year, I drilled a hole, in the body, and installed some grease Zerks, hoping to get me through the rest of the season. It took some of the noise away, but not all...
I pulled the deck out, (super Easy to do....) and started to inspect. Both of the idler pulley bearings were bad. Even though there were two Idler Pulleys, they were different. I even found some cross threaded nuts and bolts from the factory.
I headed into the shop for some disassembly.....
Anyways......
