windward
I started this build at the end of last September. It has taken a long time to get to where I am, but considering my wife and I are doing a lot of the work and the fact we had a brutal winter, I am happy with the progress.
Size: 24' x 44' with a 6' x 16' bump out for bathroom and utility room
Construction: ICFs, 6" core frost wall, 4" core for walls
9' walls
4/12 roof, attic trusses
3' over hangs on the eves and 2.5' overhangs on the rake.
In floor radiant heat
LP Smartside 4x9 sheets.
16' x 7'9" garage door to the West
8 x 7 garage door to the East
Cedar Shakes
My goal was to make this look similar to the house, which is a 50's ranch with large overhangs, cedar shakes and tongue & groove siding. We wanted it to look as though it was meant to be on the property and to nestle into the surroundings, as well as a 1100 sq ft building can on a 1 acre lot. We are on Lake Michigan and I will have a view of the lake from the shop.
Probably the first question people will have is why ICFs? A buddy of mine is in the industry and was willing to give me the ICFs, if I paid the shipping on them (not cheap, but reasonable). He also wanted to use my garage as a test run at panelizing the ICFs, instead of building them in place. (I will cover this more in a later post). Wisconsin winters can be rough and since I plan to heat the space, I don't think I will regret all the insulation.
I hired an excavator (who has since become a friend) to prep the site. I also used him to trench in the utilities later on.
Because I was bringing water and gas to the building I was worried about a slab heaving, so I decided to go with a frost wall. Where I am building is a bit lower than the road, so we went down about 3ft, then built the ICF frost wall up to 50"(10" footing, 40" frost wall). Once I backfill and pour the floor, I will be level with the gravel road, and not likely to have a water issue.
I had the ICFs shipped up from Dallas. The driver wasn't too excited about backing down a 1/2 mile single lane dirt road, but at least it is straight as an arrow. On the way out he clipped two of my neighbor's mailboxes with the back of the trailer, which I ended up replacing.
I hired a mason to help me do the footings. He agreed to do time and materials, so that I could offset the costs with anything I could do. This also gave me access to his tools. He let me grab his saw and rebar bender to do that work when he was not around. I thought this worked out great. I ended up with a very square and level platform to start from.
Next I started laying out my ICFs. They stack like legos and I used a spray foam adhesive to attach them to each other.
That is my start....I will try to post more tomorrow.
9' walls
Cedar Shakes
