Disney
OK, So I got my in ground LED lights the other day. The electrician looks at them and just scratches head. I admit... I have done some too. What i don't fully grasp is a great way to install them.
What my current plan looks like is to take some 6" PVC pipe and drive it into the ground so that it will be slightly below the surface of the concrete. Then take a piece of 1/2" (or thicker) plywood cut out to the same OD of the light "flange" and set that over the tube. Then the electrician can run wire into each tube, the concrete guy can pour the crete and finish to be flush with the plywood. I would then pull the cover off and just drop in the lights.
Anything wrong with this plan????
The body of the light is slightly tapered from 5.25 to 5.50". Overall height is about 3.5". "Flange" is the section from about 3" up to the top cover and is about 1/2".
Pic of the lights for reference....
