600SL
I just ordered all the equipment required to automate my shops lighting and Compressor.
My shop has two doors one for the garage and one for the machine shop.
Goal is to be able to turn on lights for the room entered and compressor for either side. Also be able to turn on light for other room if required. When leaving any door, I will be able to turn off all lights and compressor from any door.
So I ordered 2 of these:
http://www.smarthome.com/2487S/Keyp...pad-with-On-Off-Switch-Dual-Band-White/p.aspx
2 of these:
http://www.smarthome.com/2475SDB/In...ontrol-In-Line-On-Off-Switch-Dual-Band/p.aspx
And one of these:
http://www.smarthome.com/72800/Elk-...ctured-Wiring-Panel-Enclosure-Elk-9200/p.aspx
Discussions about this can be found at the end of this thread.
http://www.garagejournal.com/forum/showthread.php?t=231499&page=3
I found the 30amp Insteon relay unit was not compatible with inductive loads (motors) so I had to go with the big ugly but cheaper ELK unit.
Attached are pictures showing the garage with two man doors prior to adding compressor shelter and the exterior compressor shelter currently being constructed.
2 of these:
And one of these:
