franksinatra
Im hoping to find someone to give me a bit of help on lighting and maybe a bit of electrical help. I have just finished installing the bottom cords on some hand built trusses in my Garage. I would like to continue to insulate and poly the entire thing finishing it off with sheetrock. Obviously before I sheetrock I need to have a few things figured out. After looking at the pictures I have added, how many lights would you guys use on my 24x24 two car garage? Also what typed of lights. I was planning on Flourescent light and adding a few over each counter top area as I figure the layout better. Rafters are 16" on center. Is there 4' or 8' Flourescents that will fit in an opening such as this? Would anyone recomend doing it this way? I want it well lit.
Now for Electrical help. I have an electrician friend coming in to finish off my sub panel in my garage that I had run 1 awg AL wiring too from inside my house. I got the wire cheap through him. When installing lights and outlets, how many units should be wired for each breaker? I would like to get an idea of what needs to happen so I can either run the wire for the lights and outlets or at least purchase the wire so we are ready to go when he gets here.
If you guys have any tips or ideas you care to share, I would appreciate it. I need all the help I can get. Thank you, G
