My Racedeck Install Experience and Results
John Harry
Pittsburgh PA
Particular thanks to Jennifer Storms at Snaplock (Racedeck) for patiently answering my many questions.
When ordering, ask Racedeck about a Garage Journal member discount. It saved me money.
Cleaning and painting the garage was a real chore, but putting down the tile itself was pretty easy. The majority of the time was spent measuring and cutting. I'm really happy with how it turned out.
Here's a few notes that might help others. These ideas aren't all mine but they helped me.
When creating your design try to consider how it will look after cabinets, tools, etc. are in place. You don't want to make a great design that will be covered up.
Measure, measure, then measure again. Draw pictures and/or make notes. Plan out ahead of time where each tile is going to go, how tiles will be laid around obstructions, etc. Mis-cutting a bunch of tile would be expensive. I put down over 500 tiles, of which 71 had to be cut. I started with 1 spare tile, finished with 1 spare tile!
Find the most visible and straightest wall and start there. Unless your floor is really out of square you'll be able to cut all the tiles on that wall exactly the same amount while still keeping the design centered and the expansion gap even. Make an L across the front and down that wall.
If you're not using a rip guide on your saw, snap them together and cut several at once, using the kerf from the previous cut as a guide rather than measuring each one.
I found that ramp tiles don't have to be lined up with the square tiles they fit into, so long as a set of loops and tabs match up. By starting my ramp tiles 6" in from the edge of a square tile I was able to accommodate 8' overhead doors without any cutting and patching.
Snapping the tiles together with a rubber mallet may be easier than stepping on them, particularly if you (or your lovely wife who is helping you) aren't very heavy.
Wuaname
Florida
Looks good. Thanks for the info. I might use some of those tips if I decide to go via racedeck
J
John Harry
Pittsburgh PA
Glad you folks like it. I'm very pleased with the result.
Wuaname, hope my experiences help you and others. Garage Journal is a great source of info from people helping people.
eEighty8
Chicago
Looks great. Your floor looks relatively level, but I'm curious as to how 'flexible' the snaps allow the joined tile structure to be? Did you have any issue with getting them all to snap together? The edges of my expansion joints sit about 1/8-3/16" higher than the rest of the floor.
Thanks
J
John Harry
Pittsburgh PA
Thanks
I had no problem getting the tiles to snap, but my floor didn't have "lumpiness" like you describe. The snaps are flexible in the sense that they allow some bending, but might not not accommodate your situation. You could contact Racedeck and ask their advice, or ask them to send you a couple of samples (or buy a few tiles) so you can try it. I dealt with Jennifer Storms [[email protected]] and found her to be very helpful.
