Swap Meet Cart
Jeff Ivers
Oklahoma
I have enjoyed going to swap meets and determined I needed something to haul purchases in. My design criteria were - sized to go through 30" door, steerable front wheels, pullable, low center of gravity, and some mechanism to stabilize large items (like signs). I'll let the photos speak for what I came up with.
This shows the sides clamped for pre-drilling.
This shows the steering linkage.
Removable tongue.
Finished cart - note the blue top rails.
Finished bed.
Removable top rails placed for load stabilization. Each rail can be placed in any of four positions on either side.
iajonesy
Iowa
That is really cool. What size is the square tube for the frame? What are the overall dimensions?
Mike
karpesh29
Minnesota
Can those rails be placed horizontally across the front and back to make a large square-ish platform? Very clever designs, and props on the craftsmanship as well! Nicely done.
J
Jeff Ivers
Oklahoma
Mike
Mike,
The top rails are made with .75 square tubing and everything else is 1" square tubing. The outside track is just under 30", overall length is 42" and width is 17". The interior of the box is 40 x 15 x 3.75.
Jeff
J
Jeff Ivers
Oklahoma
Man, I wish I had thought to do that! What a great idea! With my fab skills, I probably couldn't have got everything to fit in both directions.
Engine
Kentucky
It looks like a well made cart. Could you show more views of the steering linkage? I recently built a cart similar to yours but made the front axle pivot on a vertical pin. It works, but it's not as easy to guide the front wheels as yours will be. Thanks.
J
Jeff Ivers
Oklahoma
Here you go!
The first photo shows the cart upside down to show the steering arm (connects to tow bar), tie rods, and spindles.
These spindles are the first ones I made for my grandson's downhill racer. I decided they were not beefy enough for that application, but I think they will be fine for this cart. This photo is an early photo of the spindle before the angle iron arm was notched and bent for ackerman angle.
The next photo shows the front of the spindle (correct side up).
The next photo shows the spindle from the back side (correct side up).
Next is the top view of the spindle.
Next is the back side of the spindle in an upside down position.
And last is the front of the spindle in an upside down position.
These pictures show that I reinforced each part of the spindle by adding a piece of flat stock or angle iron to the edge of the u-shaped pieces.
If these pics don't answer what you are interested in, please hit me with some questions.
Bruce Amacker
Cleveland, Ohio
No pics, but mine's a two wheel dolly with big tires, a double milk crate, and a fold-down seat to sit on when I'm tired. The seat is the best part.
Engine
Kentucky
Here you go!
The first photo shows the cart upside down to show the steering arm...
Thanks for taking the time to post the photos of the steering assembly. It really helps me understand how the parts fit together and steer the cart.
I've never tried to make one like this, but I know this is the correct way to do it, if you want the cart to be easy to steer. I'm going to take some time to study the pics and try to make something like you have.
Thanks for the ideas and the help.:thumbup:
J
Jeff Ivers
Oklahoma
Good luck with your project and keep us posted on the results.
Burl
Where Mountaineers are free
I've got something like Bruce. I can't tell you how many times I've fallen (or nearly fallen) over a pull-behind "wagon". Usually there is a sleeping kid in it (who should be home).
J
Jeff Ivers
Oklahoma
Hmmmm. Maybe I should add some flashing LED lights or perhaps one of those backup warning beepers that is modified to be on all the time?
