DIY weld fumes extractor
toofart
Qc
Last winter I did a few projects where the amount of smoke and dust in the shop felt unsafe, so I knew I needed something. In the summer months I work with the doors open, but when it's cold I don't want to lose all the heat.
So I made my own fumes extractor with scrap I had lying around. I used an old bathroom fan which is rated 130cfm.
The head is a standard 4" household elbow, which I can pivot in any direction, and attach a variety of 4" adapters or even a length of flex pipe if I need to extract fumes for farther away.
Home made pivots using scrap metal and cheap bolts and a bit of grease. Works great.
I closed up all the doors, cracked a window, turned it on and welded for a few minutes without any noticeable smoke in the shop. Total money spent is about $70.
gorilla
Nice job. Smart of you to extract the welding fumes at the table level and not **** fumes past the breathing zone.
T
toofart
Qc
Thanks.. That's what I was going for.
Very good. How about something with a wider mouth feeding into the flex?
Yep. The advantage of using household 4" duct is the wide range of inexpensive "adapters" I can attach.
T
toofart
Qc
Does it pull shielding gas away if you get too close?
I would assume so, but if I place the head 10" up in the path of the fumes I think it's OK. I think the smoke rises but the shielding gas does not.
tarbellb
Oregon
Looks good, and for $70 your a fraction of a pre made setup.
Question: did you do anything on the outside to push the fumes/smoke away from the building?
I wonder what the local codes call out for something like this? Probably something ridiculous and expensive?
fnieto
Tucson,Arizona
Nice job,
Most if not all noble gasses ( shielding gasses) are way denser than air so it should work great for you.
As far as the discharge, I don't think your set up pose issues with neighbors.
I own a professional Arecology fume extractor (roll around) that works great but it has a large Donaldson type filter so no need to plumb outside.
T
toofart
Qc
I did nothing on the outside. My neighborhood is 1 acre lots, so neighbors are not close by. I only weld occasionally in the winter, so I don't think this will bother anyone.
With a more powerful blower I suppose one could filter the air before it escapes to the atmosphere, but I'd assume the micro filters capable of cleaning the toxic junk would be expensive. I just needed to vent :)
Beemer533
Syracuse, NY
Very nice! I may be missing it, but what is keeping the arm in place? Is it just tightening the bolts at the joints or something else?
T
toofart
Qc
The arm is held in place by the friction of the bolts. I put some chassis grease on the joints and snugged them up good.
Hephaestus29
Indianapolis
In the summer time a simple fan blowing out a window or even set up in the overhead doorway or entry door would work.
I have a blower motor from a furnace I hang in the window that works real well.
Grinder Bill
I installed a vent hood above the welding table. It's also a great place to hang lights...
T
toofart
Qc
I was originally thinking about a hood as well. That's a great setup you have.
The cold season is slowly creeping upon us, so I'll be testing out my contraption soon enough.
T
toofart
Qc
It works real good for work I do on the bench but otherwise I'd need an extension or a wheeled unit.
Nonetheless it works at creating ventalation even if it's not exactly over the fumes.
youngnstudly
The "Whine" country, CA
That's just like the setup we had at my previous employers HVAC shop, and it worked excellent! I keep wondering about using a kitchen hood with my little work bench setup, since a few members on several welding forums suggest using a kitchen hood.
The main problem is the cost of a decent 48" setup new (with the light and variable speed options I want). Might have to hit the local recycler up one of these days.
Andy
T
toofart
Qc
I hear you... I'll be starting a new trailer build soon, and with the weather in the 5*F range ain't nobody going to weld with the doors open.
