Uses for Arbor Press
Johnny A
mass
Arbor Press uses? I have useed it for bearings. Any other crazy ways to use it?
We all have seen some great ideas on this forum.
Arbor Press & what we can do with it..:lol_hitti
J
Johnny A
mass
Thanks. I missed that when I searched the topic.
Great info, thanks for the info.
Jmatlock88
Installing and removing bushings, bearings, seals, studs
Installing dowels, alignment pins, threaded (key) inserts, roll pins, t-nuts
Bending, joggling, and forming small sheet metal parts in combination with custom made dies
Die cutting or hole punching leather, cloth, gaskets, light sheet metal, plastic
Broaching
Metal Straightening
Installing inlays
Installing guitar frets
Light riveting
Installing and removing gears and pulleys
u-joints
Crimping cables and wires in conjunction with dies
Small tire bead breaker
Ball joints, tie rod ends
Reloading (shells/bullets)
Compressing springs for assembly, etc.
RivennHewn
PNW
Fairly affective for removing toenails if stored on the floor.
Especially so if in conjunction with flip-flops.
Twisted Sid
CA
I have the HF 1ton and have used to for lots of bearings and bushings on different things.
I also made a bolt on attachment to turn it into a small press brake using this http://www.grizzly.com/products/6-Vise-Brake/H3245 I had to moddify the bottom just a little to fit the spread of the arbor legs but I can still use it in a vise too.
