Show your Railroad Rail Anvils
Provincial
Near Salem, OR
Here is one I picked up at the local scrap metal yard. It is pretty well built, and has the hardy holes. It is 3" wide, 6" high, and 18" long. The base flange is 6" wide. I haven't cleaned it up yet, just used it again tonight! :beer:
Spudland_Dave
Maine
Real nice Find The Copilot! I've got a couple sections of rail at home i've been wanting to do this with. Would you mind grabbing some dimensions of yours so I can try my hand at duplicating it to some degree?
blueflame6
Northwest Ct., U.S.A.
Copilot, Mine pales bigtime to yours...........simple rail track, simple design....now maybe I should get to work on it again?? :beer:
Davefr
OR
From a G-sale. I didn't make it.
drivesitfar
CoPilot: nice thread and i'm still jealous of your RR anvil find. it's an awesome looking piece of old US steel.
WWIIII: CoPilot is right on about using these to pound cold steel on. the real anvils were only made to hit hot steel on and there are a lot of folks that use a real anvil for cold steel and that's why the edges chip off and can alter the real anvils ability to be used correctly. since real anvils are not cheap or easily made the RR track is a great option if you can find a piece.
All: here's my favorite piece of RR track i own and i have several pieces laying around my shop/garage. i'm also including a tin knocker's anvil that i used as my Avitar on GJ for a long time that was made to be used with tin or the thinner gauge steels.
Here is mine from Sunday, definitely a before pic. I've wire wheeled since where I could reach, but It will get an E-bath and some cleanup work done as well.
Right at 14-1/2 Lbs, 16" long, 4-1/2 H, 2-5/16 wide.
This one was definitely from lighter rail.
It's amazing how similar some of these are. I really do think someone was manufacturing these at some point from old rails.
That's an old truck housing. We used to see Mod A housings made into jack stands all the time... I have a couple from back in the day.
Joe B.
Yup. Other than being amazingly rusty it would make quite a good stand. Heavy & stable but also with spots that one could bolt on a rack to hold things like hammers or what not. I wish I could have kept the stand but I just did not have the space at the time. Now I could find a great home for it.
Provincial
Near Salem, OR
Joe B., that stand is the axle housing from a tractor. You can tell by the fender mount ears halfway out the tube, as well as the bosses for mounting the 3-point lower arms.
This is a great thread! Many interesting anvils.
cherokee140
Shoot mine is just a hunk of rail....I have also found tons of uses for the spikes as well...
GOOD steel in that stuff.
jeremy v
Here are mine. Two large ones that are both the same rail size, and one small one. All 3 were found at garage sales over the last 2 years, and I paid a total of $5 for all 3. The two large ones used to be one long single piece, but it was too heavy to move easily, so I torch cut it into two roughly equal length anvils. I shaped the ends of the small one for general use banging on things, and I rough shaped one end of both the larger ones. I stopped there, because I am trying to decide how far I want to take the modifications. I am sort of waiting for the usefulness of different features to become apparent through actual need rather than just adding a bunch and possibly never needing them.
My other chunk of RR track: This one is even smaller gauge (or whatever the sizing metric is) than the shaped track is. Only 4-1/4" tall 2" wide on top 4-1/8 or so on the bottom flat, and 4-3/4" long. 6-1/2 lbs, so right at 16-1/2 lbs per ft.
You can see where someone got serious on it on the near edge.
Got this a couple of years ago at a yard sale, and keep it on the bench for just beating on stuff. where there is no finesse needed.
The round disk was my dad's "anvil" for inside the house, or at least that is where I found it. a hair over 6" round.
I'd like to find about a foot of the heaviest track available for my "Power hammer" setup being made from an old 50's power nailer. It would be a good piece for that. I'll probably wind up getting just a stray chunk of steel for it. I used to have a much thicker disk than my dad's, about 4' thick and 8 or 10 wide. not sure what I ever did with it...
yotie
Southern California
So not really knowing about anvils I picked up a 15lb hf anvil, heated up a peice of steel placed it gave a few wacks and I was leaving big dents on it, hahaha, so I Picked this up, cleaned it up a little, paint, its 12 inches long..aww its so much better.. :thumbup:
shopdog00
Puget Sound
This has been in our family for at least 50 years.
Gary
lotsoftools
Inland Empire
Out of the dozen or so RR anvils I've made and sold, here is the one I kept for myself. Nothing fancy, about 6" long and 5" tall.
Davefr
OR
Here's another one I found today. (pretty nice machining)
Spudland_Dave
Maine
I've got one in progress as well...love the pics, giving me ideas all the time.
So back a couple months ago when I Was googling Track Anvils, i found some info that this anvil project may have been a common "Shop Project" in schools and this is why we see a fair amount of "Similar but different" creations from all over the place....Just figured I'd add that to the conversation. Once I get mine done, I'll post it up.
Jere
Anyone else have their RR anvil turned end up? I need some ideas for a better stand?
yotie
Southern California
I wound like to make a stand for mine, right now its on a tree stump.. I would like to get a 1 foot "same size as anvil" section of "I beam" for the anvil to sit on top of , bolted or welded to "I beam", then use a 4x4 metal square tube for middle stand, then maybe 1/2 inch plate steel for the base,, not sure how much a llittle peice of "I beam" will cost...
MPOWERD
This is great stuff... So much heritage here in these anvils. You guys make me proud to be American!
I think I can fab one of these from some abandoned rails not far from where I live... They tore up the line and left a few rails behind about 8 years ago. I think they are still there.
ZRX61
Solar Blight Valley, SoCal
https://scontent-lax3-1.**.fbcdn.net/hphotos-xfa1/v/t1.0-9/423366_2924950615613_1173552001_n.jpg?oh=06eaa91f2564590beacd6be3e1405434&oe=5672751E
https://scontent-lax3-1.**.fbcdn.net/hphotos-xfa1/v/t1.0-9/396528_2924954495710_1769547549_n.jpg?oh=8506e85666e72a4cae502034a272c7bb&oe=56742C0E
mg283680
Any hints on cutting down chunks of rail? I have an ~12" section that is good and another ~24+ that's a bit unwieldy. I was thinking of cutting the longer one into a few 3-4" sections and squaring the ends better on what remains.
I've heard chop and belt saws are inaccurate, but power hacksaws are getting rare.
36truck
UP of Michigan
I have 4 pieces of rail about a foot long. Guess I need to build some anvils out of them. I also have a BIG chunk of round stock that's about 10" across by 12" tall that I use as an anvil. It sits on a piece of rubber mat. Works great for beating on.
WWShop
MN
I actually just picked this large one up this morning. I'm still friends with guys at my previous job and I knew they had this laying around. Found my next project for shaping the larger of the two. The small one has been very handy too.
