HF mill/drill $600
ngray
Maybe that's the price now, but I paid like 450 after the coupon last year, shipped.
J
Jawn
Stuck in traffic, GA
Looks like the HF one has a slightly larger work envelope and greater travel. The G0704 has variable speed though. I was seriously considering that one, but the HF one came up for half the price, so I'm giving it a shot.
J
Jawn
..... maybe wrong thread on this discussion but can you elaborate on this "Round column-pass" ?
I'm new to machining, so pardon my terminology (may not be accurate). When you loosen the clamps to be able to raise/lower the head, it may move side to side due to the round column, thus forcing you to re-establish the head's position in relation to the work. I realize this is a hassle, but for the price I figure I'll just deal with it.
PT Doc
The round column deficits were well explained. As long as you know this and plan as best you can, it should work well. The rf45 style solves this issue with the square column. More bucks though.
zeekh
Upstate NY
Dealing with it can be difficult at times.
J
Jawn
JonnyC
Green Bay, WI
Seems like a really good deal. For the work I would need to do though, it would be better to go with a mini-mill.
danny_barkley
FL
For some of us less enlightened can you describe what is helping you make this observation? If I bought a mill I would want it to be capable of being CNC converted.
JonnyC
Green Bay, WI
I'm not very enlightened, but most of my work right now is on smaller aluminium parts. There's a lot of parts and information out there for the mini-mill, including CNC conversion kits. Plus it weighs a ton less for moving it into my basement :) I doubt I will get a mill though. Right now my work is doing done on a lathe, and I can use my drill press as a ghetto mill for what little stuff I need to do.
ineedtools
SouthWest Florida
The griz 704 has a fanatical following, I've been saving for one. Considered the HF but after reading and seeing one in person running mach3 I decided on the 704 as kits are readily available for $650. The guy that showed me his griz said that you'd spend many times over on tools and tooling for the mill than what you paid for it so it seems to me that starting with a good one makes sense.
macgee
Sepulveda Pass, CA
Deal is dead, back to $1200.
I did get a tracking number though, so mine's on the way.
Bummer, at only $600 bucks I was actually going to jump on this for my home for random jobs. Already have plenty of R8 tooling at my shop.
Glad u were able to get one. You'll have to do a write up after u set it up.
lrhredjb
Central IN
My round column allows me to swivel the head completely away from the bed and use it as a drill press or to mill something too big for the bed. I can groove tires with it(as an example).
I can fly cut some very large things with it.
I don't have a square column machine but imagine with a LOT of work and lifting they would do the same...or maybe they have a pivot in the base somewhere....
Did you modify the machine to be able to do this?
You can buy mini-mills with tilt columns, usually 45° left and right. Most hobby machinist agree that the lack of a column permanently affixed to the based means worse location repeatablity.
J
Jawn
Well, they tried to deliver it. After I was told by the freight company that yes it would be on a truck with a liftgate, it shows up with no way to get it to ground level. Back to the terminal it goes, and they're going to get back to me on what it'll cost to have it re-delivered on a liftgate truck (or else I'll just go get it).
J
Jawn
This has turned into "Oh I need to buy this too..."
I bought a stand from wttool
I bought an engine crane to unload it from the truck and set it on the stand
I bought assorted tooling from enco and ebay
My wallet hurts. But here's a pic of it set up. I borrowed a pickup to drive to the freight terminal to get it. To unload, I busted the crate apart, removed the belt cover, and wrapped a chain through the hole in the head casting. Getting the belt cover off is a PITA though... have to remove the belts, spindle pulley, tensioner pulley, disconnect wiring from motor, remove switch from side of machine, and a bunch of bolts holding it all together.
diggerrick
Dad has the older geared head version. It works great, but he had to modify something in the spindle so the collets would fit. (In the back corner of the photo)
Okay experts, what is the difference between a drill-mill ans a mill ?
These 2 topics (mill-drill vs mill and round column vs dovetail square) are very closely related.
Expert, feel free to correct me. A mill-drill has a fixed table and the head and quill move up and down for Z-axis adjustments (full sized machine have a fixed head and the table moves up and down). Typically, there is a coarse and a fine hand wheels for Z-axis movement. The coarse typically moves the whole head up and down while the fine moves the quill within the head.
The head is mounted on a column, either cylindrical or square w/dovetails. The cylindrical column allow the head to be rotated to either side so that if there is clearance next to the mounting stand, your "table" is the floor. Handy especially for woodworking projects where work piece might not fit between the quill/collet/chuck and the table and vice.
Some mill-drills can tilt their column left or right 45°. With people have actually use this feature and going back to 90° takes some work to make certain it is square to the table.
The complaint about the round columns is variability every time you move the head (not the quill) up or down. The square columns with dovetail have much less variability as you raise and lower the head.
Digital read outs (DROs) are optional on all of these machines. Many have been converted to CNC. Some people have done customization for larger tables and/or more X and/or Y travel.
MadMechMaster
Frankfort, IL
I have one(round column), and haven't done much with it except small maintenance jobs where tolerances were loose.
When I did look into solutions to repeatability in locating the head after moving it, I found a suggestion to use a laser pointer rigidly mounted to the head. If you mark a spot on the wall across the shop, say 15', then if you move it away and back, you can be reasonably close to where you were originally. If you mark a plumb line, you can stay in one vertical axis.
