VacMaster vs. Craftsmas wall mounts
Okay, got to set it up and try it out yesterday. My comparisons are based on the VacMaster vs. the Craftsman. I also have a shop vac (smaller, 3 hp model) as a reference.
The VacMaster came nicely packaged with 4 accessories, 2 pc. wand and two sections of hose-one regular and one slinky / contracting type. Set-up / mounting was easy and took all of ten minutes. Construction quality seems on par, if not better than the Craftsman. The plastic isn't that super hard / scared you're going to break it type - it's got some flex to it. So may products anymore seem like no thought or design went into them - this one doesn't. Little things like the on-board storage, handle design, cord wrap, etc. Just like the mounting bracket - one vertical line of 3 screws vs. a side by side arrangement means you can mount it to just one stud.
The switch on the unit has 3 settings - on / off / remote. When trying it out, I found it hard to remember that I had a remote-kept walking back to the unit. The good news is that it will reach all of my 500 sq. ft. shop with no problem.
Hoses are interesting. As I said, one is 'standard', and one is a stretch kind. Not sure how much it stretches, but it seems to have about the right amount of tension - not too much, not too little. The only issue I can see with it is if it was stretched and you set it down, it would retract and scoot across the floor. Also, each hose has one locking end only-the other ends are friction fit. They seem to hold well though - even with the cord stretched.
The size difference between the VacMaster and the Craftsman is huge-the VacMaster is much smaller and compact. I think a lot of it has to do with the bottom tray on the Craftsman, but overall, the VacMaster is a lot more compact.
The VacMaster does follow one of my pet peeves with the Craftsman- the hose jutting out from the front of the unit. You can kind of solve that problem on the VacMaster by using the accordion hose at the unit. It's more flexible and doesn't stick out as far as the solid hose.
The VacMaster is much quieter than the Caftsman, or even my small ShopVac. More along the lines of a standard floor vaccum vs. a wet-dry vac. Just a guess, but I would say 60% or so of the noise of the Craftsman.
As far as what really matters, performance, I didn't have a lot to clean, but it seems to do fine. At least as good as the Craftsman. I'll have to make a mess and give it a good test. It was able to **** up a small screw even through the brush-which gives up a ton of suction.
Overall, so far, I prefer the VacMaster. Seems better thought out and designed and all of the little things add up to make it easier to use. I think the remote will be nice-once I remember to use it. If both units were the same price, I would definitely get the VacMaster-I might even give it a premium of $50 or so over the Craftsman.
