Use of terminal blocks
600SL
Connecticut
I will be running conduit around the perimeter of my building and placing large junction boxes 90 cu and 111 cu along the ceiling where conduit will drop down from the ceiling to feed a receptacle. 12 #10 conductors consisting of 2 three wire 240V circuits and 3 two wire 120V circuits will pass through each box and up to 7 conductors may be tapped out for power (one box will have up to 17 conductors tapped out to feed a partition wall as well as the receptacle).
I know that wire nuts are a suitable solution in these boxes but I would also like to consider terminal blocks especially in that partition wall box. I believe it would be a lot cleaner solution.
The only problem is I have never seen anyone do this and am not sure if it would be a code violation.
I have found below a 12 circuit terminal block that seems to do the job perfectly. All 5 circuits will be on 30 amp breakers.
Can anyone comment on its use.
1) Would this count as a device for volume calculations?
2) Is it OK to put up to three leads under one screw using loop connectors?
3) If I used two 6 circuit terminal blocks is that 2 devices?
http://www.mcmaster.com/#5566t41/=tur0f0
irritant
Monticello or Tallahassee (awake or asleep)
http://www.wago.us/products/termina...trips-witth-cage-clamp-s-connection/overview/
although these may not be rated for the load you have in mind, they are really nice and I have used a bunch of them. I don't believe terminal blocks will count as devices, but you need to make sure you pay attention to keep all voltage ratings the same. You would also need to pull a ground in all of your power carrying conduits and bond this ground to any junction box it passes through.
Rather than loading up individual screws for multiple drops, consider using bridge clips to jumper adjacent screw posts
rockwithjason
Las Vegas
if the product you use is rated for the voltage and current of the circuit and ul listed then you are good
30a circuits are generally only used for special purpose circuits. general purpose circuits are 15 or 20a. there are special rules for this in the code
yes
no, use jumpers to add more terminals
you must calculate the volume of the device and then apply it to the box fill
this would work
600SL
Connecticut
Thanks for the reply
I can actually do this job with 2 leads under one screw, but my goal was to keep the lines feeding the boxes on one side of the terminal block so that I never touch that side again and let the devices get hooked up on the other.
If I use jumpers I do not gain a screw terminal unless I can put a loop with a screw required for the jumper, which seems to be the same as two loops under one screw? Is a jumper and 1 loop under a screw OK or perhaps limit each screw to 2 loops?
As far as 30 amps that is nice to have but not necessary.
alfredeneuman
Fullerton, CA
.....my goal was to keep the lines feeding the boxes on one side of the terminal block so that I never touch that side again and let the devices get hooked up on the other.
The load wires will still be energized. I don't know why that makes a difference.
My brother, a Union Journeyman, tried that method on a service change with a generator panel. It was a very neat job. The inspector turned it down because of the fact that the terminal block was not UL listed, only recognized as a component for machines that would be listed, and the attached wires could not extend for 3" outside of the box.
He finally ended up pulling the existing wires out and using wire nuts, having learned that it's not better to "reinvent the wheel".
Kevin C
Portland OR
The part is UL recognized, not UL listed. Basicly, the recognized matters when you are getting an entire assembly listed (tested). You submit the paperwork for the device and they don't need to test that component. They still need to test the assembly and verify the ratings on each component.
My take is that unless there is a specific approval for the part to be used for this specific application, its not code compliant. That doesn't mean it wont work or could would not pass certification test, but you would have to have your entire assembly tested.
justsam
Penngrove, California
Trying to wire local distribution with 10AWG is going to be a pain. Connectors such as WAGO are readily available to gang up to eight conductors, but only up to 12 AWG. You are going to have the same issue when it comes to terminating outlets, lighting, etc.
I would strongly consider establishing a subpanel, or otherwise re-routing such that your wire runs and conduit conductor count de-ratings do not require the use of 10 AWG unless it is required for a specific singular device such as compressor, welder, etc.
600SL
Connecticut
This is exactly why I'm here asking the question. Thanks.
600SL
Connecticut
Thanks see my reply to alfredeneuman.
600SL
Connecticut
These are strictly for 120v and 240v outlets. Sub panel or not to eliminate derating will require 4 conduits which is just too ugly and they would ultimately end up in the same boxes unless I put in more boxes with conduits going all over the place. In the end the wire nut count ends up the same. Only in one case would I be twisting 4 wires together but there will be about five 4 wire twist and seven 3 wire twist in that one 110 cu box required to feed the partition wall. I believe Mike Holt has pictures of all that wire stuffed into a 30 cu box.
This solution is clean, elegant and very flexible but the price is paid in copper. The other reason to use 10ga is because of the long run of up to 145' in some cases. I have also been reviewing my voltage drop issues of such a long run on another thread and find with 10 ga this will not be an issue. Pigtails coming out of the boxes to the receptacles can and probably will actually be 12 ga.
So a lot of complexity of subpanels and large amounts of conduit get reduced by going from 12 to 10 ga and taking the derating.
600SL
Connecticut
Looks like a rail of 12 of these will do a neat job by my partition wall.
http://www.grainger.com/product/SCHNEIDER-ELECTRIC-Trmnl-Blk-23NY13?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/23NY13_AW01?$smthumb$
alfredeneuman
Fullerton, CA
These ones aren't listed either.
"Help ensure the quality and operational availability of equipment, and optimizes installation set up and operation.
UL Recognized and CSA Certified.
Product content provided by supplier"
You'd be hard pressed to find one that is. My brother was unable to.
600SL
Connecticut
Here's a 2 post model but it has the same specs. These ones I can jump without giving up a screw terminal. So 2 of these and a jumper is half the price of the 4 screw ones.
Are these the certifications I need?
600SL
Connecticut
12 wire nuts in a 111 cu box?
Well if it comes down to not being able to use a terminal strip it still wont be this bad.
Charles (in GA)
50 mi south of Atlanta
I know you want a "clean" look and think that one conduit, or few conduits is the way to go, but in the end, you are going to have a cluster f--k with all that wire and one or two conduits and junctions. I won't put more than two circuits in a conduit, and that is enough of a mess.
Charles
600SL
Connecticut
Charles
I actually have 5 circuits in 2 conduits, 2 are 3 wire 240V 2 are 2 wire 120V and on is a dedicated 120V that happens to be going in that direction to power dehumidifiers.
Most of these boxes will have three to 5 connections. The picture I presented in the original text is kind of a worst case scenario with the exception of the box at the partition wall. The reason for two of each circuit is just to stagger outlets like what is required in kitchens.
I'm very accustomed to this kind of stuff. Shown are pictures of the main harness from a Mercedes SL600 with me getting ready to install it. The car has been running beautifully for 8 years now.
FYI- u can share 1 EGC for multiple circuits. Needs to be sized based on largest breaker. Or u could use the conduit and make sure to use bonding rings. This may help u on your fill capacities and overall ease of install!
teamextreme
Lakewood, CO
Why the bonding ring (ground bushing?) requirement? I always understood they were only required on concentric knockouts.
600SL
Connecticut
Yes that is the way the schematic in my first post shows it. I will me using a # 10 ground but I also understand that I could use a #12. I also could leave it out all together. It really is overkill with EMT and boxes mounted to steel walls on a steel frame building.
What is the size of the largest breaker that the EGC would be on? Did u upsize any conductors?
600SL
Connecticut
What is an EGC. Conductors are upsized for EMT fill. Largest breaker will be 20 amps or 25 amps if they allow it. These will all be 20 amp outlet circuits either 3 wire 240V or 115V duplex.
