roger55
Some of you may be following my workshop build thread in the "Garage Gallery" forum. Here's a link if you haven't seen it:
http://www.garagejournal.com/forum/showthread.php?t=8044&goto=newpost
I will document the progress of my Wolverine floor in this thread.
I am going to do the main floor area (660 ft2) with the Wolverine system.
(It is presently on order from AlphaGarage.)
My order:
BondTite - 3 gallons (1 - 3 gallon kit)
LiquaTile - 6 gallons (2 - 3 gallon kits of Silver Gray)
EnduraShield - 3.75 gallons (3 - 1.25 gallon kits)
DecoFlakes - 20 pounds each of Midnight Black, Snow White and Spruce Green all in the large 1/4" size
Spiked shoes
24" notched squeegee and frame
So, my intentions are to do a 5 mil coat of BondTite, a 14.5 mil coat of LiquaTile and two 4.5 mil coats (wet) of EnduraShield. This will give me a total dry thickness of 27.7 mils.
After much thought about how to prep the floor, I decided to go the hand grinding route and already have completed it.
I purchased a 7" diamond cup and put it on a new Hitachi (6,000 rpm) grinder with a Dustie shield. After trying a test area, I really had trouble controlling it. It ground too fast and I just couldn't get an even grind without gouges.
So, I bought a cheap grinder/polisher from AutoZone (Great Neck brand) just to try it out as it is a variable speed with a maximum of 3000 rpm. Well, it worked well. I was able to control it just fine. The job went a little slow however. It went at about 50 to 60 ft2 an hour so I stretched the whole job out over 3 days since it is kind of hard on the body. Here are pics of the gear and how the concrete looks:
The grinder rattles a little now. I am really surprised that this cheap thing lasted for the whole job but it did.. The seat really helped on the back and knees. Here is another shot showing the Hitachi I tried and a small HF 4 inch grinder and cup that worked well in corners:
So, now I am ready for the epoxy to arrive and watch the weather for a good 3 to 4 day warm stretch to do the coats. Luckily, San Angelo doesn't stay cold for very long at a time so I think I should be able to get started soon.
My next post and photos will be during the application of the BondTite.
Stay tuned and wish me good luck .....
My order:
Spiked shoes
