GRINDER SAFETY 101 (graphic injury video so be warned)
drivesitfar
This is not a Darwin award type thread because most or all of these injurys could have been prevented with a little knowledge passed down from those in the know.
While i was searching for new wheels for my bench grinders, hand grinders and buffers i came across this video. I might own more than most of the members and i didn't know some of the facts expressed on this video. there is some fairly graphic injury pictures so beware while you are learning the safety facts.
i learned several things in this video that i will try to make sure to do with all my grinding in the future. I have been guilty of many times not even putting on safety glasses and just used my readers for a quick job on the bench grinder.
that said i would like to find a good source for a couple of these high quality full face shields which will be hanging on my grinders to use every time from now on.
Hopefully this video will help others prevent any of these injuries and also give you information to help others that are not members of a forum or fortunate to have somebody teach them correctly how to use power tools.
Edit: i added a few more videos on post #40 that are not as graphic, but are interesting and please add one of your favorites if you have one or find one or more to share on this thread.
saryon7
Wow! Great video. i have never had a wheel explode on me, or even seen it happen. I didn't realize how bad of an injury it can cause. Thanks for sharing. Will be buying a face shield.
RedneckWelder
The Ghetto Kingdom of Methlandia
You definitely want to wear a faceshield while grinding or using a cutoff wheel. Helps hugely with the sparks and provides protection against shrapnel from the wheel or even the material you are working on.
Personally one of the things I wear a leather welding jacket for is for heavy grinding use, which usually occurs while I am welding.
Somewhere either here or another board there is a photo of a very pricey Miller welding helmet that stopped a grinding disk shard from ******* up the user's face. The wheel actually penetrated but stopped.
D
drivesitfar
wow i think i want to buy that shield especially since i like using very old grinders and their wheels.
I've heard of the big grinder's wheels exploding and knocking holes in the walls and roofs of the commercial buildings and homes they were at so even a shield won't help in some cases.
probably best to stand to the side to be a little more safe from an exploding one.
any online links to where to purchase the nicer full face shields would be helpful if you own one you like.:thumbup:
thebeekeeper1
Illinois
A pic of a 4 1/2" exploded grinding disk made the internet rounds a few weeks ago--half of it stuck into a guy's cheek. Explodey stuff is serious stuff. :O
PCO6
Newmarket, Ontario
woodstockva
USA
To add to this topic....in case anyone is interested in preventing accidents with grinding wheels.......earlier this year I did a video on how to "ring test" your bench grinder wheels (to ensure there are no hidden cracks that will cause failures aka explosions).
<iframe width="560" height="315" src="//www.youtube.com/embed/NDtL4gisZYo" frameborder="0" allowfullscreen></iframe>
Thumper68
Duluth MN
Had a 12"x3" wheel let go in the welding class I was in. It was a fresh wheel, first time spinning.
No one was hurt, scared the hell out of the instructor who had installed the wheel and flipped the switch, in this case the switch was off to the side of the 3 phase machine.
I have never seen a set up the same the off switch was in the normal spot in the center of the machine and the start was off to the side, my guess it was set up to keep the operators hands and the thing being ground far from the wheel on startup.
madison069
Monroeville, PA
Funny you bring this up, as I'm working on a craftsman block grinder and I am going to replace the wheels with wire wheels. as for that Bionic Sheild the link you provided Redneck is one that's uncoated so it will fog up, the PN for the coated anti fogging lens is S8510
SantaAna12
Thank you.
3M on the mask here.....I will take a look at the uvex...I had a pair of uvex safety glasses....nice gear.
Any thoughts on the tilt-up vs. the ********?
NVM.....I am sticking with the 3M.
mooman
CHICAGO, IL
I find it interesting that a grinder safety video shows an angle grinder in use with the guard off (2:11) and the side guard off on a block grinder (6:20)
torqueman2002
... i would like to find a good source for a couple of these high quality full face shields ...
drivesit ...
First, thanks for the video and promoting shop safety. I know I am guilty of taking common shop tools for granted and have been fortunate to have only taken a couple of layers of skin off.
Next, I have and use a full face shield. It's comfortable and passes ANSI Z87+ and CSA Z94.3 standards.
$29.50 with Amazon Prime - S8500 Uvex By Sperian Bionic Face Shield
http://www.amazon.com/S8500-Uvex-Sperian-Bionic-Shields/dp/B0040C10KI/ref=sr_1_3?ie=UTF8&qid=1411659493&sr=8-3&keywords=S8500+Uvex+By+Sperian+Bionic+Face+Shields
All - Here's a link with more Grinder Safety related info. [and links to other resources].
"Craftsman Block motor Bench Grinders - What's the Fuss (with resource information)"
http://tinyurl.com/CM-Block-Grinders-Why-the-Fuss
wrenchguy
NW Indiana
getting ready too put new 14"x3" wheels on my 1250 lb. monster, i guess i'll look into more safer operation. thanks.
jakemac
New England
At 1250 lbs, there is no safe option but crossing your fingers. If that baby lets go, it could sink the Bismarck ! :lol_hitti
scw1991
My father decided one day 20 years ago to stick a 7" grinding wheel on a 4-1/2" angle grinder (guard off). The wheel exploded and tore through the top of his left hand right up through the knuckles and severed all the tendons. Amazingly, no bones were broken but the injury left his hand pretty useless.
I use to watch him use a bench grinder and he never ever wore eye protection. He was constantly in the bathroom afterwards dislodging **** out of his eyeballs with a toothpick.
I've been fortunate to learn from my father's countless mistakes over the years and how important it is to use tools as properly intended with their guards and to always wear eye/ear protection.
metaldad
nw indiana
i always wear a face shield. gloves, 98% of the time.
surprised that video stated.......... no gloves
D
drivesitfar
Fretters: don't forget shirts not tucked in and i'm sure there are others.
TM: thanks for the information on the shield you use and if i can't find the ones in the video i'll be buying the one you use. also thank you for adding this video to your block grinder thread that highlights a lot of the things a block grinder owner needs.
Wrench: make sure those stones pass the ring test and I for one really like that HUGE grinder you have.
All: some stones are made from a different material so won't pass the ring test and I think TM and a few others have mentioned those. At the very least check for cracks on a stone and even if you don't have a guard on the side i'm pretty sure you are asking for trouble if you try to grind on the corner or the side of a stone.
I bought a welder's jacket to use when i use my Baldor buffer with wire wheels on it and for sure I'm going to wear a full shield mask.
i'm sure a lot of us are guilty of using a grinder or a tool without safety precautions. i remember grinding off some lead paint off a steel bench without eye gear or a mask. i could smell the lead paint in the air and had a slight cough for a while after that one.
Stay Safe everybody and please keep adding comments and questions because i'm sure there are plenty of other issues that haven't been discussed.
D
drivesitfar
WoodstockVA: thanks for making that Youtube video and i remember seeing it several months ago. i'm not certain your ring test works for every type of grinding stone so do you have anything to add to that video?
woodstockva
USA
Thanks! I hope it saves people from getting injured.
I do not know if this is an "effective" test for very large grinding stones....but I know for the smaller (6"-10") bench grinder wheels, it works very well.
I am sure people with experience with the larger ones could chime in & tell us the correct way to test those varieties.
General Geoff
Allentown, Pennsylvania
Gloves are same as loose hair, ties, loose sleeves etc. where machinery is concerned. If they get caught, you're dragged in.
I can see how this would apply for leather or durable fabric gloves which would indeed pull your hand in with them, but what about latex or nitrile gloves which would simply tear off of your hand (and not pull your hand in) if they were caught? I typically use nitrile gloves with death wheels and grinders to keep shrapnel from embedding into my hands, which can be quite painful if not particularly harmful.
torqueman2002
The 'Ring Test' is primarily applicable to vitrified bonded wheels.
"How to Perform a Ring Test on a Grinding Wheel." - Norton - pdf file.
http://tinyurl.com/Grinding-Wheel-RingTest-Norton
Here's another pdf file from Norton's (©Saint-Gobain) site.
"Bench Grinding Wheel Do's and Don'ts." - Norton - pdf file.
http://tinyurl.com/Norton-Grndng-Dos-and-Donts
Fretters
South Yorkshire, England
They should be safe enough as they're not a loose fitting glove. If you get close enough to snag one of those, you're going to be losing some flesh anyhow. :D When anything snags it's not just the strength of what catches though. The initial ****** can be enough to get you, even if whatever it is then rips. As with owt though, just use some gumption and you should be fine.
General Geoff
I've found that as long as proper respect is given to the tool and the laws of physics, even with catastrophic failure no limbs will be lost. This is why I always make sure to keep my body out of the plane of rotation with any cutting wheels or grinders when using them. It might be a little awkward to do sometimes, but I'm not getting a gut full of shattered wheel.
D
drivesitfar
Fretters: I'm thinking they are talking like a Burr King or Baldor belt grinder like this one. it will chew a piece of metal down to nothing very quickly.
www.burrking.com and in case you were wondering and they aren't cheap.
I'm sure they have their own issues to be safety conscious about, but they are nice grinders.
Fretters
Ah. I wasn't even close. :D
Aye, most accidents tend to be due to avoidable errors. Occasionally Sod's law just has it in for you no matter what, but more oft than not it's just plain silliness or distraction which is to blame. Watching some people doing their thing is like watching an accident waiting to happen. It may not get them anytime soon, but you just know it's going to happen eventually.
It's like if the wife ever asks me if she can borrow a sharp tool. It's always a simple no in response. I once decided to trust her, and she ended up in A&E. Seriously, who would swing a hatchet towards their hand and not expect the worst. My wife is obviously one. Wouldn't be so bad, but I'd spent ten minutes showing her how to do what she was wanting to do so that there was no way she could hurt herself. As soon as I was out of sight, she started doing it her way, and the inevitable happened. :D
Fretters
Thought it might be the linishers. If the belt lets go, it's less catastrophic. I know of quite a few who prefer using those over standard bench grinders. Apparently keeps the piece being worked cooler too.
D
drivesitfar
Fretters: knife makers love those Burr King grinders because they don't ruin an edge with proper use.
ALL: Here are a few more videos in case you want to learn a bit more or to confirm what you already know. not quite as graphic as the first one.
there are many many more if you care to post some of your favorites on here. my god some of these guys are having their friends and wifes film them while they grind without proper safety and put them in harms way too.
i'm learning a lot more respect for these great tools that i didn't have and took them for granted that they would just work when i needed them to.
