OverkillYJ
So I need a tubing bender, but all I find at decent prices are pipe benders. Seems tubing benders are quite a bit more.
So I go this 10 ton hydraulic ram with a porta power I just picked up cheap. I figured I would be a good fit for a home made bender. I would make it removable from the rig so I could still use it or replace if needed. The tube bender is something I would only use once in a while. Primarily to bend this 2 1/4" DOM 1/8" wall tubing for a roll cage on my Jeep.
I see the designs of these are simple. I have an oxy acetylene setup I recently acquired. I figured I could cut the upper and lower plates they use to make benders out of 1/4" plate. The thing I cant find are the rollers. I need ones like the ones on benders.
As for the die, I only need two sizes. I figured I could take piping with the same ID of the tube I want to bend. Heat it, bend it, then cut apart the bend to gusset the back side of it and make a die to fit the end of the ram.
I want to make sure this is a good idea. I do understand the stresses involved which is why I plan on using single pieces of steel plate instead of piecing something together.
I also was not sure if a bottle jack would be a better idea than a porta power ram. I like the porta power ram though because I do not want to have to stand so close to it the first couple of times I use it. With the porta ram I have 2-3ft of space to move into a safer position while making sure it works fine the first few times. That way if something did break I would not be on the receiving end of it. Although, with two piece bender design on legs I do not think the odds of failure are high. And I only use grade 8 hardware on everything I make.
Amy input or design ideas would be great. This is something I will not do for at least a month since I do not need the bender right this moment. I figured I could make something safe for about $50 and 5 or so hours of work.
The pictures are just the style bender I am thinking of. Mine would be mounted sideways though since I would be bending some pieces that will have more than one bend in over 10ft of DOM. If it was strait up and down like that bottle design pipe bender I could see issues with it. I cannot find these little wheels anywhere though.
By The way. The other size Die I need to make is for a 4 link suspension in the front of my Jeep as well as a custom drag link and track bar. So that is a little smaller tube, but walls are thicker. I refuse to buy these parts for pieces they list when I know I can make them. I do understand a lot of engineering has gone into them, but I am making everything else from scratch anyways so nothing I could buy will fit my application for under $1500 for the front suspension alone. With a bender I will be around $400, or maybe a hair under with the heim joints paid for. I know of no kit for converting a leaf sprung YJ front to a coil front with a 5" stretch forward and a HP Dana 60 front rear.
