zuspiel
I've had those pliers for a couple of months now and wouldn't want to live without them anymore. They are awesome. Here's some pics to start with:
They have a 11:1 ratio built into them so even with minimal pressure on the handles, you get a really good grip on whatever you want to hold.
The jaws are smooth and so don't mark what what you're gripping:
I came across a great test: Removing carb studs. Here they are in action:
And here's the stud after removal:
NO TOOLMARKS!!! nissan_crawler, are you listening?
Two of the studs came right out, the other two needed a bit of PB. I'd estimate that it took about 30 ft-lb to get them out. And that's smooth yaws on a round stud... And, yes, I know they make extractors for those. You gotta do what you gotta do...
Any square or hex bolt is no problem whatsoever and they don't push out the corners like an adjustable wrench. I guess I've applied as much as 50-60 ft-lb with those things (gas tank drain). I would imagine that they'll also be mighty useful for plumbing but wasn't forced to try that, yet.
Verdict: You need a pair!
