I can't say that there is or isn't more current draw, but the harder you are working some of these, the more you better have an XC battery. It's not for the amount of working time, but the amount of work output you need. one 3" hole through brick vs 100 1/4" holes through brick, same motor speed, same time on the trigger, guarantee the drill is working harder through that one hole than the 100 combined.For drill/drivers, battery capacity has no impact on power. They don't draw enough current for it to matter. Bigger battery just means longer run time.
I can't prove a damn thing but I can tell you anecdotally that the drill/drivers unquestionably have more power with the XC batteries. I DID NOT expect this, so this was not me deciding upon an expected outcome. I was somewhat surprised to discover this.
Again, if you want hard data or facts there's no way I could provide it to you, so argue away, but I know what I've experienced.
I think 1 2.0 and 1 xc 4.0 is a perfect setup. Does anyone like the fact that the xc 4.0 battery makes your cordless impact m12 fuel stand up on its own easily? The battery makes a good platform for the tool to balance on. Does this make sense? Does anyone like the xc batts for this?
I feel like the xc batt sort of defeats the purpose of the m12, because the m12 tools are so compact, the xc batt makes them look like the m18 tools right?
Are 1.5 batteries able to stand up the same as 2.0?
Also I believe milwakee advertises a power gain from the xc batteries. I assume there is a noticeable deference between 1.5 and xc 4.0 batts.
NOT saying your wrong- but I've used my M12 drill and impact a LOT, with both 4.0 and 2.0 batteries, and for driving screws, drilling holes with spade bits, etc, there's no difference in my experience. It's certainly possible you've done different work than what i've done and noticed some change.
