Moved here a couple years ago with dreams of having an awesome garage.Its a 2 car under the house. Well..spending money like crazy on a fixer-upper has delayed everything quite a bit.
But, with my tools and everything being so disorganized...I really cant wait any longer. I gotta have a decent workshop.
So far Ive finished removing the old sheetrock on the one wall (it was really rough). Put in some fresh R13, and put up mold resistant sheetrock (leftover from basement project). Just need to replace a couple rotted sill plates with PT wood, and then can really start moving.
I know the sheetrock work isnt perfect..But, after all. This is just a garage..It doesnt need to be living room perfect.
As you can tell the 2 car garage is separated by a load bearing wall. I know..terrible design. I should put up a beam with a few lally columns and get rid of it..but I think Ill just live with it. Makes the house more solid with a full 2X4 wall anyways. No bounce in the floors whatsoever.
right now Im just focusing on one side of the garage.
My plan is to do a large work bench from the subpanel, extending to the other wall (last pic). Probaly just made of 2X4s and 3/4 plywood on top. Id like to top it off with sheet metal. So if I get grease on the work bench.. Just wipe it up and thats it.
I also have 500 sq ft of black and white VCT tiles. at 50 cents each, and 20% off that..I couldnt pass it up.
The problem is that the floor is pretty pitted, and poor patching needs to be removed. Basically it needs a new skim coat. What type of cement product should I use to skim coat?
I wont be regularly parking cars on the VCT tiles either. this will be primarily a workshop.
Ive also seen some moisture in the concrete before in one spot...It just looked damp. Havent seen it in a long time, but I wondered if it came from the ground.. so, I figured to play it safe I'll go ahead and seal the floor before putting down VCT tiles. What type of sealer should I use??
I'm also thinking of building cabinets to go above the workbench. Would look a little cleaner than just using one of those peg boards. Was thinking of just building most of it out of plywood. Could use a router on the doors to make it look decent. Task lighting under the cabinets.
Id like to just build a bench and save the rest of the work for another time..but, if I want a floor, now is the only time to do it. So practically need to do it all at once.
Thanks for looking and I appreciate any opinons!
