honda1998civic
Very small water drip at shower valve threaded connection. Can Teflon tape withstand heat? All the connections are copper and sweated up to the threaded connection to shower valve body. It held for as long as a week with leak test but yesterday a drip started. I don't see how because I tightened the connections until I basically have one or two threads showing. I used Teflon paste thinking that was better than the tape. I know I need to try and get another round on connection now but it's all sweated together so I have to cut line or heat up solder to disconnect. I'd like to disconnect as close to the valve body as possible but will Teflon tape withstand heat when I sweat lines back together? Also are the threaded connections tapered? I did back off maybe quarter of a round on one of the threaded connections because it was not lining up. I had already sweated the elbow to threaded connection along with six inches of line so I could solder away from the valve body. Any suggestions are appreciated. Is Teflon tape versus Teflon paste a preference or better in certain situations?
