Need Suggestions on dreaded"frozen hood latch"
rcm296
Timmins, Ontario
hahahah as topic states, heres the scenario
Live in northern Ontario, Canada, wintertime it gets to -40celcius lots of times throughout winter.
Yesterday my dad, who does'nt have a garage, calls me, his hood latch is frozen, i managed to get it open, without $$%^&^& the cable, but ended up breaing one slat on the grill, trying to get screwdriver on the "spring mechanism" to pop the latch.
What a good product to prevent it from totally freezing again , have tried dry graphite lube and white lithium grease.
GDA
Dallas, Texas
Boil a small pot of water and take it out there and shoot some boiling water at the mechanism and hood with a turkey baster.
Works for car doorlocks too.
Depending on location - slush and ice are hard to prevent building up just from winter/storm driving. Just keep it lubed well with white lithium grease.
speed bump
Butte Montana
That works until you get about to about -10°F or so, then you just froze the lock really good because even boiling water freezes pretty darn fast.
GDA
Dallas, Texas
Agree. I grew up in Iowa and in wintertime had to thaw out a couple doorlocks over the years. Depending on the driving and conditions there is no be all cure.
R
rcm296
Timmins, Ontario
i found some at one our local auto parts stores..once again us Canucks get ripped off.lol
cost me $70 for 4 litres. I am so cheap and used to getting most my other penetrating lubes n stuff like that free from the mine, forgot how expensive some these products are:). gonna wrap it up and give to the father as a gift, more i read on this product"Fluid Film" more i liked, father has a houseboat , so be good on that, snowblower(always freezes up), etc etc....even my tools in my job bag(gets damp and humid in there)
SteveU
Seems like lock de-icer would work on something like this. I used a bit of synthetic ATF on mine to loosen it up & it has worked since.
gofastman
Minnesota
First, use a powerfull solvent to clean the latch mechanism thoroughly, get ALL that white lithium grease, grit, and grime out of there, white lithium grease has its place but its deffanetly NOT hood latches. That alone should make the biggest improvement. Next spray some penatrating lube like wd-40 or pb b'laster in there, that will drive out all the moisture and keep things working smoothly.
