Lowes: Kobalt Direct Drive 3/8" Ratchet/Socket set down to $9.95
Davefr
OR
Looks like Lowes hasn't had much luck selling their new direct drive 3/8" ratchet + socket set.
I see the new price is $9.95 and the local store has >>100 in stock.
Price and avail. might be regional YMMV.
http://www.lowes.com/pd_607975-2202...&cm_mmc=AFF_CJ-_-4485850-_-1122587-_-10926682
donthelegend
St. Louis, MO
Played around with one in the store. Seems to do what it claims, but the head is rather bulky. Seems like if you need an extremely small swing arc then you may not have room for the larger ratchet head either, but YMMV.
For 10 bucks I'm considering picking one up because I think it's a cool ratchet, but I'm not sure how much I'd actually use it.
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
The sockets are SAE + Metric spline, which isn't so good. Usually want separate SAE spline or Metric spline if going the spline route. So wouldn't put any value into those sockets. I've heard the rachet is pretty decent but haven't tried it. A 70 or 80 tooth probably is not too different in capability though of degrees to turn. If it turns in 3 degrees vs. instant, does that really matter? - Paul
vjquan
I almost bought one just to try out, but as I was playing with it in the store, it still does have a little play, maybe a degree or two, for it to engage. I thought the most slight movement would engage it, but it didn't. Didn't seem to be much different than a fine tooth ratchet (compared to my 84T). That and the fact that the head is large, like the old round heads made me think twice. I certainly don't need any more ratchets, but would still like to hear user experiences. May still pick one up for novelty sake based on what others post here.
jpr278
For $10 I'd try it just for the ratchet. Unfortunately none available where I'm on vacation across the street from a Lowe's, at home or ship to home.
D
Davefr
OR
The biggest complaint I've heard, other then the size of the head, is lack of feedback. (if you can't see the ratchet/fastener and can't hear any clicks you have no idea what's happening).
However at $10, if it helps you just one time then it's paid for itself.
I agree those combined SAE/Metric sockets look like gimicks.
unslow1
Illinois
You can use this.
10%
47000RRRRR3558R
exp- 01/15/15
Replace each "R" in the code above with a random number (the code is all numeric). Usually takes a few tries to get a code to work.
Here's a code that you can use. Took me 2 tries, but I verified it works.
470003773835587
If for some reason that doesn't work, that means someone else used it, and you'll need to modify the sequence of numbers.
D
Davefr
OR
You can use this.
10%
47000RRRRR3558R
exp- 01/15/15
470003773835587
^^^Thanks. At $8.98 this becomes a no brainer.
tweedlestan
Palmdale, CA
I bought a set just for the ratchet. The head size and mechanism are very similar to the Snap on FZERO gearless ratchet. Mine has no play at all, it's a true 0-degree ratchet. I have no complaints.
unslow1
Illinois
Same here. I just got home with mine. I like the ratchet but probably won't even take the sockets off the rack. I guess I'll just toss them in my loaner/give to friends stuff box.
SCscoutguy
South Carolina
I can get the regular set but would like to get the one with the palm ratchet but it isn't carried in my store nor is it available to ship?
D
Davefr
OR
I agree. I picked one up a lunch today and it's a pretty nice ratchet. I think it's worth having for those situations where you're extremely limited in clearance.
It grips with almost imperceptible swing.
bfm336
St. Louis, MO
100's available in St. Louis area, but none with bonus palm ratchet :(
Tempted at $9 but based on large stock I should probably check back in a few weeks, maybe get a price adjustment lower ;)
ishiboo
Oshkosh, WI
I have a gearless Titan, though one of those 1/4" mini ratchets... I like it. Might have to pick one of these up and see what happens.
jonathan75
NC
Just not looking forward to in store pickup. My Lowe's every time you pick something up in the store they act like it is the first time they have ever done it. And when they walk over to pick the item up they can never find it. One time it took over 30 mins and they finally found the item in the back of the store.
vjquan
I got to play with one at the store again, this time out of its packaging, and it did not have any play as others have mentioned; it was the package slop that I was feeling earlier. A couple of things to note: 1) the length is about 7.5" and the head is 1 5/8", kind of like putting a 3/8" drive in a 1/2" body on a normal round head. 2) It feels pretty hefty, like you're picking up a 1/2" drive ratchet. 3) It's not a sealed design; the circlip gap on both sides is quite wide, maybe 3/8", so dirt and gunk will surely get in. It certainly wouldn't be my go to ratchet due to these cons, but nonetheless, is cool to play with.
shybuck34
Michigan 517
My store honored the deal with the bonus palm ratchet, they just adjusted the price of the palm ratchet to .01. Just showed them the price online.
unslow1
Illinois
It's back up to $20 here in IL. I hope they put something on clearance soon. Most of the stuff here has been marked back up. They did take down almost the whole DeWalt section. I wonder if that is set for clearance soon.
Docman
Confirmed, now $19.9x at the local store where I had bought it for $9.9x a couple weeks ago.
unslow1
Illinois
I got one back in the summer.The thumb release is defective will not allow the socket to lock in and when you tap a socket on you have to pry it off.My fix was to add a 3/8 to 3/8 adapter.Did not want to deal with returning it after prying the set off the plastic packaging.The sockets are junk I have not tossed them yet but its coming.I do feel the ratchet is useful in tight places.I thought I might give Kobalt tools a try.But after this I will pass.
Most Kobalt tools are much better than those. I bought the same kit for $9 and never even took the sockets off the rack. I'm not a big fan of Kobalt because I think they are overpriced. The quality seems generally comparable with Craftsman or Husky. They do clearance them at reasonable prices. The sets when they are on sale are a great deal. Perfect for my enclosed trailers and garage across town.
Bigblue&Goldie
I checked one out the last time I was at Lowe's and I was impressed with how smooth the ratchet was, but I won't be buying one. The reviews I've read are generally negative and the head is huge and the handle is short.
platypus20
camillus, ny (syracuse)
I have a couple of them, I like them. The first ones I got were defective, would lock up solid, the replacements have worked fine. At first the directional switching was bulky/cumbersome, but has freed up with a little use. If they go back to $10, I definitely pick up a few more.
oak_park
Chicago
It's been 19.98 for a while but I noticed its down to 14.98 now. 130 of them in stock here.
Item #: 607975 | Model #: 86773
elronin
Hialeah,Fl
Wow 130 in stock my local stocks have about 100 each have a feeling they may go for 10 bucks again one day. Or go back to 20 bucks you never know with Lowes
CNGsaves
KS and OK
My Lowe's shows it at $14.98
Got one as Xmas gift but haven't had chance to try it yet. Short-throw might come in handy but will see if worth using. If nothing else, the ratchet will remain in the "ratchet drawer" collection !! ;)
