Show us Your Vintage ratchet before and after restoration!!
Faisal
Saudi Arabia
Show us Your Vintage ratchet before and after restoration!!!!!
hi guys
let us see your vintage ratchet before and after restoration and let us share the experience and skills in restoration :beer:
i will post all new and old post of my vintage ratchet here
i will start with Craftsman "BE" 1/4-drive ratchet with a forged body and female drive broachings
for more information about the ratchet you can visit this site
https://home.comcast.net/~alloy-artifacts/craftsman-be-hcircle-p2.html
tools used
1-paint thinner for cleaning
2-evapo rust
3-wire brush
4- Hook and Pick tools
5-WD40
6-sand paper 200,400,1000 grit
7-super lube and and 3 in 1 oil for the drive Pully Ball
8-phillips screwdriver
F
Faisal
Saudi Arabia
part2
F
Faisal
Saudi Arabia
this is Craftsman "BE" 3/8-drive ratchet with a forged body restoration
tools used
2-evapo rust
3-wire brush
5-WD40
7-super lube and 3 in 1 oil for the drive Pully Ball
8-Phillips screwdriver
F
Faisal
Saudi Arabia
this is 3/8-drive Williams B-51 reversible ratchet with insets for the reverse and side views. The shank has forged-in markings "B51 The Superratchet Patd." on the front, and "Drop-Forged J.H. Williams & Co." with the W-Diamond logo on the reverse. The reverse face is also stamped with the "Williams U.S.A." logo.
The overall length is 6.3 inches, and the finish is chrome plating with polished faces.
The ratchet mechanism has a 24-tooth drive gear with a pivoting pawl, and the shift lever is loosely coupled to the pawl to allow independent movement. The design is described by patent #1,957,462, issued in 1934 to W.C. Kress.
tools used
2-evapo rust
3-wire brush
5-WD40
6-super lube and 3 in 1 oil for the drive Pully Ball
7-flat screwdriver
8-needle nose pliers
F
Faisal
Saudi Arabia
part 2
F
Faisal
Saudi Arabia
this is Craftsman C-97 1/2-drive open-style ratchet with its drive plug, stamped with the Craftsman block logo and model number on the shank.
The overall length is 8.5 inches, and the finish is chrome plating with polished faces.
The drive plug has a circular end cap, a style popular with some makers but which requires that the plug be removed to changed directions, rather than simply pushed through to the other side.
released between 1932-1936.
https://home.comcast.net/~alloy-artifacts/craftsman-early-tools-p3.html
Tools used in the process
1- paint thinner for cleaning
2-dremel rotary device and small wire wheel
3-superlube white grease
4-WD40
5- Turtle Wax Chrome Polish and Rust Remover
Tronyadorable
Looks good bro ! Did you ever look into the electro-less nickel setups ?
F
Faisal
Saudi Arabia
this is Craftsman "BT" 1/2-drive reversible ratchet, marked with "Drop Forged" forged into the handle, and with "Made in U.S.A." forged into the reverse. The head is stamped with the Craftsman block logo, and the small "BT" manufacturing code is (faintly) visible between the two screws at the bottom of the head.
The overall length is 9.6 inches, and the finish is plain steel, with extensive pitting due to rust.
This ratchet has a rather unusual arrangement for the shift lever, in which the lever arm passes through a hole in the forged body so that it can be actuated from the opposite side. Readers familiar with the Vlchek Tool Company will recognize this immediately as the Vlchek WSSR10 Reversible Ratchet, and a comparison of the photographs shows that the tools are basically identical except for the markings.
Apart from the unusual shift lever, the ratchet is a well made but conventional dual-pawl design with a 28-tooth drive gear.
This "BT" ratchet was first listed in the 1936 Sears Spring and Summer catalog as item number 6155, with a $1.98 price. Sears later included this model as the standard ratchet in otherwise all "BE" style socket sets.
4-WD40
6-turtle wax heavy duty rubbing compound
7-sandpaper 400 grit and 1000 grit
F
Faisal
Saudi Arabia
part 2
SquareLJ
Nothing like what you have, but I've recently started collecting some older Snap-On ratchets.
1951 - 1/2" drive NO. 71-M
1949 - 3/8" drive F-71-A
1942 - 9/32" drive M-70L
Used a pick to clean out the screw slots, wire wheel to knock off as much rust/corrosion as I could, Dawn dish soap to degrease them (dried immediately after to prevent rust), then some Never Dull to bring out some shine. Then, a coating of Mobil 1 synthetic wheel bearing grease. I'm new to cleaning old tools, I'll try your method of paint thinner and look into evapo rust.
F
Faisal
Saudi Arabia
this is 3/4-drive Williams H-51 reversible ratchet with a forged handle, stamped with the "Williams U.S.A." logo on the reverse face (see middle inset). The shank has forged-in markings for the model number and "Superratchet" trademark on one side, with "J.H. Williams & Co." and the W-Diamond logo on the reverse. Additional markings "Drop Forged" and "Patented" are also forged into the reverse.
The overall length is 19.0 inches, and the finish is chrome plating.
The patent notice refers to patent #1,957,462, filed by W.C. Kress in 1933 and issued in 1934.
https://home.comcast.net/~alloy-artifacts/williams-supercompany-p4.html
4-WD40
7-Needle-nose pliers
F
Faisal
Saudi Arabia
part 2
F
Faisal
Saudi Arabia
this is Williams No, E1-24 THE SUPERECTOR 1" square Ratchet Wrench 25" Length
please if any body know any thing about this ratchet please share it with us
2-bosch drill and dremel rotary device
3-wire wheel many sizes
4-superlube white grease
5-Needle-nose
6-WD40
7- Turtle Wax Chrome Polish and Rust Remover
8-screw driver flat
F
Faisal
Saudi Arabia
part 2
F
Faisal
Saudi Arabia
this is Craftsman "K-Circle" 3/4-drive fine-tooth ratchet, stamped with "Pat. No. 2188846" and the Craftsman double-line logo, with a "K-Circle" manufacturer's code at the right.
The overall length is 17.7 inches, and the finish is chrome plating.
The patent notice cites patent #2,188,846, filed by T. Rueb in 1938 and issued in 1940, with assignment to the Sherman-Klove Company.
The Craftsman double-line logo and chrome-plated finish on this ratchet suggest production in the mid to late 1940s. & SOCKET SET
2-dremel rotary device and small wire brush
4-Needle-nose plier
5- 3 in 1 oil for the drive pulley ball
6-WD40
F
Faisal
Saudi Arabia
part 2
F
Faisal
Saudi Arabia
part 3
F
Faisal
Saudi Arabia
that is really cool collection :thumbup:
land
Lafayette, LA
Nice restoration on the craftsman box! I have a similar one that I have been meaning to restore. Mine is shallower and has a divider on the insider........i think it originally held a 1/2 or 3/4 set.
F
Faisal
Saudi Arabia
go ahead and restore it ,believe me its worth :thumbup:
and show us your restoration pls :beer:
F
Faisal
Saudi Arabia
F
Faisal
Saudi Arabia
part 2
F
Faisal
Saudi Arabia
lordabraxis
Fredericksburg
Great work work on your restorations! I work at Sears and part of my job is rebuilding ratchets and sometimes I get ones returned that we don't rebuild (discontinued models) but I like to tear them apart and try to make them work anyways. I still have 2 that I just couldn't get myself to throw in the "scrap tools" barrel.
F
Faisal
Saudi Arabia
perfect :thumbup: because i need somebody working their to ask him about some part for my ratchet
i will pm you soon
thanks
F
Faisal
Saudi Arabia
Hi guys
This picture for most of my restoration tools
F
Faisal
Saudi Arabia
this is Craftsman "BE" 1/4-drive open-style reversible ratchet, stamped with the Craftsman underline logo and a "BE" code on the top cover plate.
The overall length is 5.2 inches, and the finish is chrome plating.
The ratchet is reversible by rotating the pawl to work on the other side, and the side edges of the pawl are serrated to provide a grip (see top inset). The pawl bias is maintained by a spring-loaded ball carried in the pawl itself, rather than in the handle shaft.
https://home.comcast.net/~alloy-artifacts/craftsman-be-hcircle-p3.html
XxToolAholicxX
SF **** Bay Northern California
Did you spray paint them? If so what kind and code please? By the way excellent job.
I am a Toolaholic,Sometimes I regret it,Especialy when the Toolman wont give me no credit
ChrisPace
Damn! I enjoyed looking through this thread! Love and I mean love the old restored Craftsman tool box. Seems like you could use a small blast cabinet and a vibrating tumbler polisher to work on some of these. I would love to see some of these old ratchets re chromed too. Wow, great stuff! I may have to find an old Craftsman box to restore.
F
Faisal
Saudi Arabia
NO, I never repaint my ratchet i just clean,lubricate and make them shining again
but for the craftsman toolbox i used KRYLON smoke gloss gray and gloss banner red
F
Faisal
Saudi Arabia
great :thumbup: find the box and show us our skills
