I just went through this process last month. The Quickjack videos looked cool and it's had a lot of positive reviews. I'm not a big fan of the hydraulic fluid, lines and a pump...but it looks like they did a good job of making it compact, and the price is $650 less than the EZCarlift. I
really wanted to like this unit. The main thing that killed this lift for me was the relatively narrow 50" lifting points. This is barely adequate to reach the jacking points on my 2 smaller cars...so I was very concerned how this might limit its use for other vehicles. If you search this forum, you'll see others with the same concern.
I understand the popularity of the Quickjack. I think it's the best "bang for the buck" lift out there at $1295 and free shipping. But if price is not your primary concern, I think the EZCarlift is a unique product that is tough to beat.
Here's where I think the EZCarlift lift beats the QuickJack:
- Raises car higher than QuickJack by a few inches
- Wider lifting points: 60" (expandable to 66") vs. 50" for the QuickJack
- Complete accessibility to underneath the vehicle...even from the sides
- Mechanical simplicity - no hydraulic lines, pump, fluid, nothing to leak or connect
- No external power source required (The right cordless drill will work with an EZCarlift!)
- Optional casters let you push your car around your garage while it's on the lift.
- Safe design...raise it as much or as little as you want. No worry about safety stops.
- Extremely compact when stowed away.
- Can be used for things other than just lifting a car.
EZCarlift Negatives:
- It costs 50% ($650) more than the Quickjack BL5000!
- It can "only" lift 4400 pounds (that's good enough for me)
- The width of the lift is determined by the cross bars you select. You may need additional cross bars if lifting multiple vehicles with different widths.
The EZCarlift is expensive because it's not being mass-produced in China. It's made of quality materials (steel, aluminum, etc) that are machined and hand assembled in the US. It's a fascinating device and doesn't look or feel like a cheap product. When you call the phone number to order one, the guy who designed it answers the phone! How cool is that?!?
Needless to say...I bought an EZCarlift and I'm very happy with it.
