FS: Craftsman block grinder parts (part 2)
tool_scrounge
Southern California
California
These parts came from a couple partial Sears Craftsman 1/3 HP block grinders (part number 397.19580 ) - an example is shown in the photo below. I suspect some of the items will fit other model block grinders. Shipping not included. I usually ship out USPS since it tends to be the cheapest.
Link to manual:
http://vintagemachinery.org/pubs/222/2202.pdf
Everything below for $11 + shipping
Stator/coil 3175501, two Screw,8-32x1 3161742, Toggle switch 5310072, Start relay 3181341, Cable assembly 3175512, Strain relief 3169206.
Works fine, but the outer jacket on the power cord is missing in one spot about 45" from the grinder as shown in the photo.
Three wheel flanges 5218554, Left grinding wheel nut (1/2"-20)125996, Right grinding wheel nut (1/2"-20) 120371, 2 Spring washers 5211995, 3 Thru bolts 3168677 with nuts, 5 Clip springs 3161432, Self-tapping screws 9417077, 2 stamped metal flanges, one grinding wheel spacer (home made?) plus other misc.
The wheel flanges look to have been overtightened as the have been bowed in some.
