Oily Rag Can
Stephenw
Utah
I've been wanting an oily rag can for a very long time. They are a little spendy, starting at about $60. The major snag has been difficulty in getting one. They are generally not available at your local hardware store. An industrial hardware store that is on my way home from work has them in stock (but they are $90). Today I went to Harbor Freight to get some chip brushes and nitrile gloves.
I scored this...
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=37506
The container was only $14. The quality is also very near to those which you can buy from an industrial supplier.
Uncle Buck
Kansas
That is a perfect example of something you can buy at HF that really cannot be screwed up! Well done.
bchee
Texas
seems like a sweet deal. I'm not exactly sure what it does though:eek:
The link doesn't show the price
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
Thank you very much!
I have one that I found at one of my "junk" stores (damaged freight), I gave around $30 for it. I've been wanting a second (wood shop verses garage rags, don't like to mix things).
mkdive
NPB (Socal)
good idea on the rag bin.....i should have one of those in my garage. looks like a trip to HF this coming week.
Stephenw
Utah
Under the right conditions, it is possible for dirty rags to spontaneously combust. A pile of dirty rags in a regular waste basket or laying in a corner of the floor could burst into flames and burn your shop down. I have heard that it is more likely to occur with rags that are soiled with natural oils such as linseed or other nut based oils. It is said that the possibility is low with motor oils or other automotive chemicals. I still feel it is a good idea to get the proper disposal container.
The item number, 37506, does not come up in the online store www.harborfreight.com.
The website for items available in most local stores is www.harborfreightusa.com.
It is my understanding that prices can vary from store to store, thus, the reason for lack of price information on the website.
dxdexter
This is one reason why I never throw dirty or oily rags in a bucket. I always hang them over the edge of my large garbage can for a day or so (to dry out) prior to disposing of them. Engine oil is not to bad, but thinners, linseed oil, furniture finishing products and other volatile chemicals can spontaneously combust or create fumes that can be readily ignited in the proper conditions.
Stephenw
Utah
How do you eventually dispose of the full can of oily rags?
I suppose it depends on your local law. Empty it into your burn barrel. Empty it at your local hazardous waste collection facility. Empty it into your trash can on pickup day (after you have put your can at curbside, away from your house).
toddjg
I scored this...
where is it made?
3 at 8
N. E. Ohio
I must be an el cheepo, I wash mine at least a couple of times. Wife won't be happy with you though after she smells what you've done to the washer. :mad: So I've learned to first give them a quick soak/wash outside in a bucket of simple green before they go in the washer. Went to my HF this morning; they didnt have any.:(
davestlouis
Lake St. Louis MO
A neighbor of mine had stained his deck, then threw the rags in a trash can. The explosion blew the overhead aluminum garage door onto the cars in the driveway, then burned the house down to the foundation. Lesson learned!
IDASHO
Moscow, Idaho
Your oily rags dry out, huh? :headscrat
Uncle Buck
Kansas
I take my old red rags to the local laundry mat late at night when no one is about and run them through their machines a time or two!:eek2:
yellowbox
i use old t shirts that i dont want anymore then burn em , make great fire starters for the campfire pit
wythors
I have this same can from HF. The floor of it is unfinished, very thin gauge metal and is rusting severely after about 5 years of use. It should rust completely through before too much longer.
jay50
:headscrat I would think that oily rags would somehow coat the inner metal and provide a little bit of rust protection....but again, this is a HF product so the metal is probably paper thin...:bounce:
Danglerb
SoCal
My rags are auto related only, oil and dirt, and I put them into a bucket of simple green and water until its about full, then toss it in the washer for a double run. Putting them in a dryer I've heard can be dangerous since the oil and gas never is completely removed in washing, but our drier is barely warm even on the cotton setting.
Spontaneous combustion, at least as I know of it is related to mildew. If the HF is rusting, that means moisture is present. Why not spray it with Rustoleum or something?
IDASHO
Moscow, Idaho
More often than not those HF items are painted in cheap enamel.
Know what enamel does when exposed to petroleum based products?
Stephenw
Utah
Today at the office, I took a really close look at an oily rag can. It was a Justrite brand and was made in the U.S.A. I didn't mic the steel to be sure, but it appeared to be the same gauge as the can I purchased from Harbor Freight. It was not painted on the inside either. The design and construction looked to be identical. The only difference that I noted was that the Justrite brand can had a UL Listing tag attached to the top of the lid.
russlaferrera
Central Virginia
Gee, he spent $14 for a can. Now everyone is bad mouthing HF. For $14 , what does everyone want, a $90 can for $14? Just Rite is the higher end, that's why they are $$$
MAD
Western MA
I have been wanting to get a proper rag bucket like the one in the original post or a while. Now I use old paint cans with lids to keep oil and solvent soaked rags sealed up. It would be nice to just use the paint cans for the really nasty ones.
Bolster
Mexifornia
Stephen if you get the chance you might also want to post in the "HF PASS/FAIL" thread. Thanks for the heads up.
nissan_crawler
Wichita, KS
Like I always say, you don't walk into HF expecting to buy a cadillac for the price of a geo.
However, choosing between NO can between my shop and spontaneous combustion, or a perhaps (I'm not convinced of it) not as good metal can, I'll still take the metal can.
The other part of me wonders why somebody let bare metal get to that point of being rusty in the first place without doing something about it.
eschoendorff
Stop it, just stop it!!! You are making WAY too damn much sense!!! :spit:
